#536239 - 09/09/04 08:30 PM Can't Get CVPI into Gear!!
jayrw123 Offline
Loc: The Big Lone Star State
I went out tonight to start the car, she started just fine. I then went to back out, but the selector is locked! I have no clue into what could possibly be wrong. This is a new one on me. Someone stated to me that they're could be an accurator like in the caprices. I know in the caprice when you depress the brake pedal, you can hear a clicking noise unlocking the gear selector allowing you to place the car into gear. Is this also true about the CV. Does it use the same setup as the Caprice. This car is going to be sold with in the next week. Thanks for the imput.
#536240 - 09/09/04 08:32 PM Re: Can't Get CVPI into Gear!!
Anonymous
Unregistered
it's your BOO switch, turn key once, shift to neutral and shift to R or D. once you put it in park you will have to do the process again.
#536241 - 09/09/04 08:35 PM Re: Can't Get CVPI into Gear!!
danatriverton Offline
It means that your brake light switch is either bad or a wire broken on it. You have no brake lights.
It is about 8 inches streight above your brake pedal under the dash.
6 registered (DES, bluejay_32, Crownver, RF_Overlord, bobb, 1 invisible), 84 Guests and 238 Spiders online.
bluejay_32 303
a_d_a_m 240
Rainbowpizza 186
DudeAbides 146
JeffBoudah 110
Moby_Vic 106
Old_Guy_Stu 89
Bangster 68
2004_p71 56
BigNSlow 56
