#60187 - 12/29/02 04:30 PM WHEELS--Standard rim width?
Martin Offline
I have been trying to determine the standard rim width for a Crown Vic some people say 7 and some 8”. The reason I ask is I just bought some 17” x 8” alloy wheels and they look kind of wide. Can someone confirm the size? The Tech section lists rim width as 7”.
Edited by Liquid (01/01/04 11:18 AM)
Martin
3.55:1 Posi
Tranco shift kit
P71 PCM
#60188 - 12/29/02 04:32 PM Re: Standard rim width?
Liquid Offline
RWD V8
Loc: World's Motor Capital
Standard size is 16x7.
NedP1, you are missed!
Trilogy #58 info @ MCM
#60189 - 12/29/02 06:01 PM Re: Standard rim width?
Anonymous
Unregistered
I thought it was 15x6.5 and 16x6.5 ?
#60190 - 12/29/02 06:31 PM Re: Standard rim width?
Anonymous
Unregistered
standard size are 15x6.5, 16x7, the 17inch Rims I m not familiar with, sorry.
#60191 - 12/29/02 07:11 PM Re: Standard rim width?
Martin Offline
Guess I will have to get a tire fitted then check the clearance. Fingers crossed. Anybody know any good tire places in the LA area?
Martin
3.55:1 Posi
Tranco shift kit
P71 PCM
#60192 - 12/29/02 08:05 PM Re: Standard rim width?
enslow Offline
Loc: Vancouver
You must also consider the offset. This created some difficulties for me when I was looking for replacement wheels.
If a wheel is 8" from edge to edge, the stud holes are not always in the middle (at 4"). I had to replace some aftermarket wheels the previous owner had put on because the offset was incorrect, and the tire would rub against the suspension during even moderate turns.
Testing the MAF
Digital Cluster Repair
Stalag's Coolant Write-up
#60193 - 12/29/02 10:09 PM Re: Standard rim width?
Martin Offline
I got these wheels from e-bay, under $500 delivered. They’re brand new and supposedly fit most Jeep Vehicles, Lincoln Towncars and Crown Vics. I asked about the offset and the guy said they would clear everything. I may wait until I see my Tax situation at the end of January before getting tires. It’s gonna suck if they don’t clear. Thanks for your input guys.
Martin
3.55:1 Posi
Tranco shift kit
P71 PCM
#60194 - 12/29/02 11:04 PM Re: Standard rim width?
93_Marquis Offline
Loc: Norwood, OH, USA
17x8 Mustang rims require at least a 1/4" spacer on the front to clear the upper ball joint. They fit the back with no problem. When you get the new rims test fit one on the front. Even without a tire you will get an idea of how close it's going to be to the ball joint.
Ray
Car: 2004 Mercury Marauder
Engine/Tranny: 49k and bone stock...for now wink
#60195 - 01/03/03 10:05 AM Re: Standard rim width?
X_Racer Offline
Loc: Marietta/Atlanta Georgia
17 X 9's with 245/45/17 tires and I love them.
2013 Nissan Leaf
2003 Town Car Signature, Class III hitch, twin air horns, 6 pack CD player, 10,000lb thermostat fan cooled tranny cooler, trailer lighting relay black box.
1999 Grand Marquis GS, Addco Swaybars on urethane, Bilstein HD shocks, Cobra 17X9 wheels with Ultra-Performance tires, Class I hitch, Jerry Spec transmission (external pressure feed to rear bearing, machined clutch basket for more plates, HD bronze truck parts Vs alum., etc...), Ford Traction Lock, 3.73 Ford Racing Gears, lowered, PI Intake, 4130N TIG welded Forward and Rear Tethers, Supersized bell intake, TIG welded Watts Link Bracket reinforcements,Air horns, Moog front end & Urethane double A arm bushings in the box ready to rebuild.
1965 VW Formula Vee, 1915cc, 120hp flat torque, 820lbs, 13x7 & 13x9 Formula Mazda wheels/tires, 5 point harness, 0-60 4.3 seconds, Koni shocks,
1967 VW Railbuggy, 1800cc, Bus Tranny, Porsche 924 axles, Rancho & Bilstien Shocks, CB
7 registered (Doctorbic, CrownVictimizer, LTC_Dave, John396, hkerekes, 1 invisible), 88 Guests and 325 Spiders online.
bluejay_32 161
a_d_a_m 106
Old_Guy_Stu 101
DudeAbides 55
Moby_Vic 54
CrystalPistol 49
RF_Overlord 45
TheCableGuy 44
Ponyguy 39
Rainbowpizza 37
