#610958 - 12/24/04 11:42 AM My car stalls when I step on the gas, Why?
90BoxCar Offline
Loc: Oklahoma
Hi,
My car has gotten to be a hard start when I first try after it has set over night or all day. It is very cold here, maybe that has something to do with it, I dont know.
But once it is warmed up it runs ok, EXCEPT if I step on the gas hard. Like on take off or to pick up quick speed. It will stall for a moment then kick in and go. The engine check light has been winking at me also.
What could be causing this? Maybe in bad need of a tune up? But that wouldnt make the check engine light come on would it? I just changed the water pump out, but I didnt do anything that would make the car stall when stepping on the gas, I dont think.
90 Crown Vic with a 5.0 liter.
Any help is appreciated, Thanks
Edited by 90BoxCar (12/24/04 11:50 AM)
#610959 - 12/24/04 11:49 AM Re: My car stalls when I step on the gas, Why?
90BoxCar Offline
Loc: Oklahoma
Oh yeah, January 2004, new fuel filter. August 2004, new fuel pump and another new fuel filter. July 2004, new valve cover gaskets and manifold gasket. October 2004, new alternator. December 2004 new water pump.
Also car seems to idle fine.
Edited by 90BoxCar (12/24/04 12:04 PM)
#610960 - 12/24/04 12:44 PM Re: My car stalls when I step on the gas, Why?
90BoxCar Offline
Loc: Oklahoma
Guess its really more of a short hesitation when you step on the gas hard than a stall out. Because the car doesnt completely die. Now in the mornings after you warm the car up and you first take off down the street it will sometimes die once on you. But when you start it back up and take off it goes fine. But like I said, now it hesitates when you step on the gas.
Im guessing probably a tune up is needed, and the IAC probably needs changed or cleaned. But would these make the check engine light come on? My other thought was maybe the Catalytic converter?
I have put some Heat in it last night and some fuel injector cleaner to see if that helps the problem.
#610961 - 12/24/04 01:20 PM Re: My car stalls when I step on the gas, Why?
Darkwriter77 Offline
Loc: Apache Junction, AZ
Idle Air Control valve will not affect your acceleration, only your idle (hence its name). But I wouldn't discourage anyone from giving their IAC a good ol' douche. I know it certainly helped with the idle smoothness on my 182k mile beast.
I'd check your throttle position sensor first and see what voltage it's operating at during WOT, using a multimeter. (Refer to a Haynes or Chilton manual for specifics.) They run in the ballpark of $35 to $45.
Check every single vacuum connection and hose, and make sure nothing's rotted out, split, disconnected, and/or otherwise not in 100% tippy-top shape, particularly anything connected to your intake manifold or throttle body. Vacuum leaks cause all sorts of fun and interesting symptoms and are often a real treat to chase down.
If you've got a timing light, check to see where your timing sits at, as it may somehow have slipped a tad back, though I doubt it.
Finally, check the local prices on a six-pack of beer. You might be under the hood awhile with this, and even if you aren't, it's always good to have a cold one at hand for the holiday, so you'd best be prepared.
CURRENT:
2009 Ford Crown Victoria Police Interceptor (former CHP), "Zeus" 170k+ miles
1997 Ford Ranger 2.3L 5spd, 260k+ miles and still going
PAST:
1994 Ford Crown Victoria P71, "Friday" (SOLD, circa 2002)
1990 Lincoln Town Car, "Phat Bastard" - 200k+ miles on original motor/tranny (SOLD, circa 2006)
1993 Ford Crown Victoria LX, "The Bismarck" (SOLD 2013)
#610962 - 12/24/04 02:51 PM Re: My car stalls when I step on the gas, Why?
90BoxCar Offline
Loc: Oklahoma
Thanks, a vacuum hose never occured to me. Ill give them a run through.
#610963 - 12/24/04 04:41 PM Re: My car stalls when I step on the gas, Why?
Camlis Offline
Loc: Essex, ONT, CANADA!
do you have any exhaust on your car after the cats?
cuz my check engine light comes on only once i'm stoped at a lite or somthing ever since i took off my Y-pipe and muffler
it might just be idling to low or somthing
#610964 - 12/24/04 08:58 PM Re: My car stalls when I step on the gas, Why?
85crownHPP* Offline
Loc: central VA
give it a tune-up and clean the throttle plate with spray TB cleaner
Pete ::::>>> resident LED addict and CFI defector
My rant on LED bulb replacements
'91 Crown Vic (badass beater) . '85 LTD Crown Vic (HPP project) . '88 P72 (ODB)
85HPP's mods:
CFI to SEFI conversion w/ HO upperstuff - headers & flowmasters - p71 airbox - Towncar seats - LED dash light-show - center gauge console - LED 3rd brake light - 3G alternator - mini starter - washer/coolant bottle upgrade - Towncar power trunk pull - underhood fuse/relay box - police swaybars w/poly rubbers - painted HPP wheels - 600W RMS Alpine driven 10-speaker stereo
#610965 - 12/24/04 10:25 PM Re: My car stalls when I step on the gas, Why?
lincolnmania Offline
Loc: tremont pa
it could be a failed throttle position sensor
1986 town car lss [email protected] 88 mph big brakes, rear discs
1989 crown victoria gt sedan [email protected] 87 mph
1991 mark VII bill blass
1987 volvo 760 wagon with 5.0/aod
#610966 - 12/25/04 12:21 AM Re: My car stalls when I step on the gas, Why?
90BoxCar Offline
Loc: Oklahoma
Seems to be running ok right now since I have added the Heat to the gas tank. Maybe it was just water in the fuel. I will see, we are going on a 2 hour trip in the morning.
Thanks
#610967 - 12/25/04 12:24 AM Re: My car stalls when I step on the gas, Why?
Loc: tremont pa
good luck and merry xmas!
scott
#610968 - 12/25/04 01:37 AM Re: My car stalls when I step on the gas, Why?
AOD Offline
TPS.
IAC.
~AOD
#610969 - 12/26/04 01:05 AM Re: My car stalls when I step on the gas, Why?
90BoxCar Offline
Loc: Oklahoma
Well we took that 2 hour one way trip today. 4 hours there and back and the car ran fine. So I guess the problem was just water in the fuel freezing due to the cold weather we are having here. I put Heat and Fuel Injector cleaner in the last tank of gas Thursday and all seems well right now.
Thanks for all the input and help.
2 registered (LTC_Dave, Lil_Al), 75 Guests and 280 Spiders online.
bluejay_32 155
Old_Guy_Stu 97
a_d_a_m 94
Moby_Vic 55
DudeAbides 53
CrystalPistol 50
TheCableGuy 47
RF_Overlord 44
Rainbowpizza 39
Ponyguy 39
