#61222 - 01/02/03 08:12 AM SUSPENSION--Right side lean found.
bigcars4ever Offline
My car has been leaning to the right so I finally decided to investigate. I pulled the wheel of and visually inspected the spring and shock along with all the bushings. I noticed the sway bar connecting rod had a torn boot and the lower ball was loose. Otherwise everything was ok. I replaced the tire and used a 2x4 and some help and checked the ball joint. They had no noticable play. I put the car back on the ground and noticed the lean was gone! I pushed on the fender and it was back. By pulling and pushing on the fender I could change its hieght with respect to ground by .75". I concluded that my polyurethane bushings on that side of the car are binding!
But I have a plan. This weekend I will drill into the bushing caseings. Then with an end mill and a hand drill I will clear a small hole through the bushing. Then install grease fittings and force as much grease as I can into the bushing. I hope it works.
Edited by Liquid (01/01/04 11:20 AM)
Mine: 2003 Mercury Marauder 300B
Bone stock for now but not for long.
Hers:
2000 GM LX Limited
Monroe Sensatracs, won't let me add anything else!
Dual Exhaust from a 99 PI. (I'm wearing her down!) HPP rear sway bar.
Quote: A car's top speed is mostly limited by the nut behind the wheel.
#61223 - 01/02/03 10:22 PM Re: Right side lean found.
2vmodular Offline
Loc: New England
Defective sway bar bushings should not affect ride height when the vehicle is sitting on a level surface. Perhaps one of your suspension springs has collapsed?
ford part numbers for recent police interceptor suspension springs are avaliable here:
http://www.p71interceptor.com/rearsprings
#61224 - 01/03/03 10:53 AM Re: Right side lean found.
lifespeed Offline
Loc: northern California
This is why I say polyurethane is a poor choice for control arm bushings.
- Lifespeed
2004 Silver Birch Marauder 140K miles
Wilwood F/R brakes, Penske 7500DA shocks, Hypercoil 600lbs F and Grand Marquis R air springs, Addco tubular sway bars, Metco control & Watts, 31 sp axles, Stainless Works cat-back exhaust, Lidio tune, BFG KDWS tires
5 registered (DudeAbides, RF_Overlord, triplej057, YoungP71dude, Joebob), 112 Guests and 322 Spiders online.
bluejay_32 161
a_d_a_m 106
Old_Guy_Stu 101
DudeAbides 55
Moby_Vic 54
CrystalPistol 49
TheCableGuy 46
RF_Overlord 44
Ponyguy 39
Rainbowpizza 37
