#615134 - 01/01/05 12:46 PM
Idler arm?
I need HELP! Yesterday I replaced the upper ball joints in my car, which took about 1 1/2 hrs by myself with simple hand tools. Right now I am trying to replace the idler arm because it is supposedly worn and I guess it is a little bit. I have the castle nut loosened and "borrowed" a 3-jaw puller(apparently they were out of 2-jaw pullers, and I didn't want to spend $30 to buy one). My main concern is: HOW THE F*CK do you get the puller installed? How do you get anything done, with ABSOLUTELY NO ROOM? I could barely swing the wrench to get the castle nut off. Can I just use a picklefork to remove this, or do I HAVE TO use the useless puller? Can I just smash down on it from above and knock it out? Who designed this stupid thing? Sorry, I am just very frustrated, like I get every time there is a part/system which seems like it was designed to be a wicked PITA on purpose! Anyone here replaced their idler, and have some secrets/suggestions? Car is up on the stands right now, so any help that anyone could give would be MOST appreciated. Thank You Good Day
1993 GM LS 243k miles 29.5mm PI front bar(ENS greaseable poly bushings),21mm HPP rear bar(ENS poly bushings/endlinks),Mechanical Stewart-Warner oil pressure gauge. Black steelies/center caps...K&N filter
1994 Lincoln Mark VIII 144k miles All airbags switched to coils/struts, junk tranny, motor donor car Mercury Owners Group
This is a disclaimer: This post is the opinion of the person in question. It is presented as nothing more than that. Furthurmore, this opinion is is not necessarily the opinion of CVN, any of its affiliates, or anyone else on Earth.
#615136 - 01/01/05 02:08 PM
Re: Idler arm?
ttt
#615137 - 01/01/05 02:51 PM
Re: Idler arm?
Loc: Kouts, Indiana
Ok if you are in fact replacing the idler arm, you do not need the puller. All you need are pliers to get the cotter key out of the 22mm castle nut on the top of idler arm. You'll prolly do best with a 6-12 extension and an 18mm socket ( not too sure on size0 for the two nuts that attach the arm to the frame. * NOTE* the stud in the frame will most likely stay in place so you do not have to worry about them slipping. Once all nuts are off you can begin to use the pickle fork to remove the arm from the centerlink. Be sure that you also take the sleeve that will prolly be siezed to the centerlink. oh and to make it a lil easier heat helps with the hammer and pickle fork cook those rubber bushings.
#615138 - 01/01/05 04:57 PM
Re: Idler arm?
Thanks for all your help! I was kind of being a little b!tch because I was pretty hungover and pissed off.... After taking a break for a second, I went back out there, gave it a few whacks and the thing popped off easy as pie. The only reason I even got the puller is because the manual(Haynes) said to. The frame bolts were kind of tricky as they were moving from the other side, so that was kind of a PITA. And, the sleeve WAS seized to the stud, and I had to get out the dremel to grind off some of it to get the new one to fit. The new arm is of a different design, and about TWICE as beefy. I wish I had a digital camera to show a comparison, because the new peice is impressive, plus with two grease fittings. Just test drove it, and although it very obviously needs an alignment BADLY, all play/rattling/shimmy is gone, and it is steering smoothly. The alignment shop where I tried to get it aligned at told me about both upper balljoints and idler arm. They said they could do it for $500. $100 each for the balljoints and $100 for the idler, plus $200 labor. I got the BJs for $80 each, and the idler was-get this-$30 with a lifetime warranty(and 2 grease fittings). I know these shops have to make money, but do they have to rape me? I simply told them that I could never afford to have them work on my car, and that I'd have to do it myself. I WILL bring it to them for the alignment, though. So-$190 in parts about 3hrs to do the job $50 for an alignment Grand total-$240 I saved myself-$260. Not bad, I'm just glad the weather has been pretty nice. If it was as cold out as it has been lately, it would have totally sucked.
The only thing about the new idler is that in the new design, the bushing is a little bit taller, so that I couldn't get a cotter pin in. Am I correct in assuming that I can just get a shorter castle nut? I just tightened the crap out of it until I can get to the parts store. So, all in all it went pretty good. Thanks to everyone here who responded, I really appreciate it. Thanks again. Good Day
#615140 - 01/02/05 10:11 AM
Re: Idler arm?
Steve83, I hear what you're saying, but look at my mileage. If the thing makes it to the point where it even NEEDS another alignment I'll be doing prety good!  But I haven't ruled it out, I found a place for $50, and other places charge $80, so it really makes sense. It's just that I've spent some dough lately and really am almost maxing out my reasonable limit for the month. Something to think about for next time. Thank You and Good Day
#615141 - 01/02/05 12:13 PM
Re: Idler arm?
Loc: Grand Rapids, MI
Sounds like you picked up a Moog arm? I think Moog is a good brand to go with for idlers because 1) they are generally beefier than the stock arm and 2) they use a solid metal bushing instead of the rubber like the stocker... Moog tie rod ends are nothing special though, IMO.
Anyways, what I do is just bust that nut off, then I shove a pickle fork in there and pound the hell out of it. If the metal sleeve from the stocker sticks to the draglink stud, just fire that bitch till shes red hot then twist is off with vise grips, or chisle at the seam...
Dead: 1994 Crown Vic LX/HPP... over 190,000 miles when she got totalled  Gone: 1996 Mustang GT 5spd, drop top, Bassani OR X-pipe, Dynomax Ultraflows, PI Cams, K&N FIPK, C&L Elbow and 75mm TB, PIAA 1700X... Dead: 2012 Mustang V6 Performance Package, Kona Blue with MagnaFlow "Street" catback. KIA August 2012
#615143 - 01/02/05 01:53 PM
Re: Idler arm?
Yes, buck, I agree that the moog arm is far and away a better design. Just makes me wonder why Ford doesn't go with something similar from the factory?
#2801646 - 01/20/14 12:42 PM
Re: Idler arm?
[Re: 1BADMERC]
Loc: Northumberland, PA
#2801658 - 01/20/14 01:10 PM
Re: Idler arm?
[Re: 1BADMERC]
I didn't use a puller. I may have just pounded on the stud to get it disconnected from the steering. I have a couple of pickle forks but I do not recall using them.
The bushing in mine was completely trashed. I replaced it with a greasable Moog unit with a bearing instead of a bushing.
#2801844 - 01/20/14 08:57 PM
Re: Idler arm?
[Re: 1BADMERC]
Loc: Connecticut
Ha ha...guys this is a 9-year-old thread that's in the wrong forum.
1997 Town Car 2013 Prius
#2802413 - 01/22/14 12:53 PM
Re: Idler arm?
[Re: 1BADMERC]
Loc: Montana
More brainzzzz...
That said, when I did mine the bushing was rusted solid to the pin so it wouldn't come out. Ended up MIG welding a bolt to the sleeve...the heat broke it loose, and the bolt gave me something to grab with vice grips so it came off easily.
1998 P71, formerly Rosebud County Sheriffs car #8 1960 Oldsmobile 98 two door hardtop 1955 Jeep CJ5 1994 Chevy Silverado 4x4 1983 Honda Shadow VT500 Custom
#2802418 - 01/22/14 12:57 PM
Re: Idler arm?
[Re: 1BADMERC]
