#618688 - 01/06/05 04:33 PM Fail-Safe Cooling
zephyr Offline
My 1998 Grand Marquis is equipped with Fail-safe cooling. The owners manual states that if the engine overheats four cylinders are deactivated and the disabled cylinders pump heat out of the engine. Also, if coolant temperature exceeds 330 degrees the engine will shut down. Sounds like a great idea if it works! Has anyone here had this feature activate on their own car? Was there any engine damage afterwards? Does Fail-Safe cooling give you enough warning? Thanks.....
#618689 - 01/06/05 04:41 PM Re: Fail-Safe Cooling
Allen Maty Offline
Loc: Southern California
That is a great question! I've read about this, but I hope I never have to find out if/how it works!
'99 Crown Victoria LX HPP w/ Digi-Dash 11/2001-12/2011 Sold! Still on road with 219K miles as of 1/15
2012 Mustang GT Premium 5.0 6 Speed Man /w 3.73 LSD. wink
For Sale: Maurader Air Intake, Zip tube & 80mm MAF with matching BOC Custom Tune Chip and ECU computer (will fit '99-'00).
#618690 - 01/06/05 05:22 PM Re: Fail-Safe Cooling
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
Last winter we had some extreem cold temperatures with -55F recorded at the airport. The radiator popped on my 98 CV and I drove about 12 blocks with the fail safe cooling mode activated. Not much of a test but it did work and there was no apparent damage. I have put about 60K miles on the car since. I believe the system alternates firing the cylinder every other cycle. It was like driving with the traction control on. No power and very little speed.
http://sask.cbc.ca/regional/servlet/View?filename=cold040129
#618691 - 01/06/05 07:27 PM Re: Fail-Safe Cooling
The thing to remember is that failsafe mode is for you to baby the car to safety. Not to keep flying down the interstate with the flow of traffic, or keep driving around all day and finish your errands.
Some of the cylinders are shut down to keep heat down, the other 4 to give you some motion. Does it work? Yes. The critical point is that 330 degrees you mentioned, when you hit that, further operation will cause damage. Prior to that, you'll survice.
Alex.
#618692 - 01/06/05 07:37 PM Re: Fail-Safe Cooling
Raptor9458 Offline
Loc: Chicagoland
Yes it works, or at least activates. Mine kicked in when my electric cooling fan failed and caused an overheat. Only problem I've had with the car since is that I have to keep adding fuel.
#618693 - 01/06/05 08:22 PM Re: Fail-Safe Cooling
Warren'74 Offline
Loc: Saskatoon, Sk. Canada
lol @ raptor!!
#618694 - 01/06/05 08:50 PM Re: Fail-Safe Cooling
ritcheyd Offline
Loc: West "By God" Virginia
Same as Raptor, cooling fan failed, baby-ed it home, no ac, pinged like crazy, no power but it did fine. Still a great engine, still had the plastic intake and still uses almost no oil. 98 CVPI with 124K miles.
2013 F150 XLT
2010 Grand Marquis
1971 Kaiser Jeep 2 1/2 ton
#618695 - 01/07/05 02:50 AM Re: Fail-Safe Cooling
1BADMERC Offline
Hahahahahaha!
1993 GM LS
243k miles
1994 Lincoln Mark VIII
144k miles
Mercury Owners Group
This is a disclaimer:
3 registered (Crown_Vic_6, Davidzq, crjackson), 46 Guests and 284 Spiders online.
bluejay_32 226
Old_Guy_Stu 120
a_d_a_m 99
DudeAbides 91
Ponyguy 72
CrystalPistol 45
Moby_Vic 44
Davidzq 43
ClayBelt 43
Bangster 37
