#634818 - 01/29/05 02:35 PM Differential Jacking
zephyr Offline
Gentleman
Can the rear end of a 1998 Mercury Grand Marquis be safely lifted with a floor jack under the differential? I went through my owners manual and also the jacking instructions under the spare tire cover and found no warnings to the contrary. The differential casting and cover have two notches at the bottom that fit my floor jack saddle. The saddle is also fitted with a thick rubber pad so differential cover damage would not be a problem. I have heard that some cars can be damaged when lifted in this area, Is this one of those cars? Thanks!
#634819 - 01/29/05 02:44 PM Re: Differential Jacking
Buck268 Offline
Loc: Grand Rapids, MI
I try to avoid center-lifting due to stability issues... Why don't you jack up each side seperately and throw stands under the frame? Takes all of an extra 2 minutes.
#634820 - 01/29/05 03:02 PM Re: Differential Jacking
AstroVic Offline
I've done it on my Crown Vics (and my wife's Expedition) dozens of times and never had a problem.
For whatever it's worth...
Signature removed. See rules.
#634821 - 01/29/05 03:56 PM Re: Differential Jacking
Buck268 Offline
I've done it as well, and it definately work, just saying I tend to avoid it because it is less stabil than jacking each side seperately. On cement this is not as big of an issue, but if your on packed dirt or something of that nature I would definately avoid center jacking.
#634822 - 01/30/05 12:06 AM Re: Differential Jacking
artosis Offline
Loc: Brookline, MO
I agree with Buck, on concrete it should be okay but on gravel or dirt or otherwise it gets pretty scary especially if both tires are off. I flattened a floor jack once with my 54 Ford, had the front jacked up with both tires off, on dirt no less. It fell over when it sank in a little, at least I wasn't under it! Guess thats why they are called FLOOR jacks!
2001 P71
Tuned/4:10's/295-50's
#634823 - 01/30/05 01:10 AM Re: Differential Jacking
1BADMERC Offline
I would TOTALLY avoid it. I raise my car on jackstands all the time. it is not recommended to jack up the car by the diff. What are you trying to do? I would jack up on the frame, then place jackstand(s) under the frame right before the frame turns up in the rear(right where you'd put the arms/pads for a lift). I just don't understand why you'd want to jack up the diff. and nothing else(unless you were adjusting ride height sensor, or tightening shock mounts/endlinks or something.....
WTF are you trying to do?
1993 GM LS
243k miles
1994 Lincoln Mark VIII
144k miles
Mercury Owners Group
This is a disclaimer:
#634824 - 01/30/05 01:24 AM Re: Differential Jacking
mybluegm Offline
Loc: NYC
Lift up each side separately and put a jack stand under the axle. If you don't have you should get them. I'd avoid lifting by differential.
#634825 - 01/30/05 01:26 AM Re: Differential Jacking
1BADMERC Offline
Do you think this is wise? What if you bend the housing/tubes?
Why not just jack up the frame, like a normal person?
This is why I was wondering what the ultimate goal was.......
1993 GM LS
243k miles
144k miles
#634826 - 01/30/05 01:32 AM Re: Differential Jacking
mybluegm Offline
Loc: NYC
I'm installing a swaybar and need the axle under pressure. Is that not normal?
#634827 - 01/30/05 03:52 AM Re: Differential Jacking
AstroVic Offline
Ramps would work better for this job.
#634828 - 01/30/05 10:33 AM Re: Differential Jacking
Ifixyawata Offline
Whoa... what's so wrong with jacking under the diff, then putting 2 stands underneath either the axle tubes or the frame rails? It's unsteady for the amount of time it's only on the jack, but once it's sitting on the stands it's fine, right?
-Brian
#634829 - 01/30/05 11:13 AM Re: Differential Jacking
1BADMERC Offline
Supporting/jacking the CAR up by the diff. or axle tubes is asking for trouble. Jack up the frame, put jackstands under the frame, and then raise/lower the rear axle/suspension ONLY using your jack. This is the standard MO. This is perfectly fine. This is why I asked you, because I thought you were talking about jacking the car up like that, which is bad IMHO..
1993 GM LS
243k miles
144k miles
#634830 - 01/30/05 01:26 PM Re: Differential Jacking
Tony_the_Brit Offline
The Ford workshop manual for 2003-5 CV's says:
"CAUTION: Under no circumstances should
the vehicle ever be lifted by the front control
arms, crossmember, rear stabilizer or differential
housing. Severe damage to the vehicle could
result."
11 Crown Vic LX Blue 151,000 m
#634831 - 01/30/05 01:29 PM Re: Differential Jacking
Kinger87 Offline
Loc: Gladstone MI
I used the center of the differential to jack the car up also. I immediately put jackstands under the frame rails to stabilize the vehicle. I find it more convenient this way, and only lift on cement/blacktop. I've tried lifting vehicles on a dirt driveway before, way too unstable, everything kept moving around..
2003 Grand marquis all stock
#634832 - 01/30/05 01:34 PM Re: Differential Jacking
jeannot Offline
Well, my 2003 Ford Shop Manual clearly indicates that you can jack under the axle tubes on either side of the diff casing, but not under the diff casing. These are actually two of the six "official" jacking points, the 4 others being on the frame behind the front wheels and on the frame ahead of the rear wheels. That is printed black on white on pages 100-02-1 and beyond.
Now for the subjective: The reason why they do not want you to jack under the diff case is probably due to the risk of damaging the cover. There may be many types of diff covers, certainly many types of jack saddles, and definitely different levels of competence.
Now to the question "why would you want to do that", I would propose that "Because I want to" be considered as a valid answer. Probably the phrase "There is a safer way to do what you are trying to do" would have done.
And to the question "WTF are you trying to do", I would propose that "I am trying to find an answer to my question, within certain limits of respect" be considered a valid answer.
#634833 - 01/30/05 01:44 PM Re: Differential Jacking
Dazednconfuzedv8 Offline
Loc: Boca Raton, FL
Whatever you do, don't jack your car up from the center differential on a slope... Lets just say my neighbor's surburban wound up in my front yard.
2006 CVPI 4.6 4V swap in progress
1985 Mercedes 500SEL 6.0 SOHC AMG
2007 Chrysler Inferno Red 300C SRT 8 supercharged
2005 Mercedes S500 w/AMG appearance package
2006 Lexus IS350 (13.2 @ 105) stock
2000 Ford Crown Victoria 5.4 powered by Vortech (for sale)
#634834 - 01/30/05 02:08 PM Re: Differential Jacking
Steve83 Offline
Always chock the tires that are staying on the ground. Don't work under a vehicle ONLY supported by a jack.
#634835 - 01/30/05 04:43 PM Re: Differential Jacking
Taxman100 Offline
Loc: Ohio
I carefully jack under the rear differential, avoiding any contact with the differential cover. Then I place jackstands on the frame rails in front of the rear wheels. Then I lower the car onto the stands, and use the floor jack to adjust the height of the rear axle, depending on what I can working on.
2011 Volkswagen Routan SE w/RSE #2 - 103K, #1 Totaled 8/14
2002 Grand Marquis LSE - 15k
1967 Galaxie 500XL convertible - 36k of old school
#634836 - 01/30/05 06:44 PM Re: Differential Jacking
black98_p71 Offline
the chiltons manual recomneds using the center of the differential for jacking
1998 P71 Crown Victoria-Stock as can be
Former Spencer,Wi police squad,Chief's take home car, In the shop
1994 lincoln continential executive series,3.8 v6 122000 miles
#634837 - 01/30/05 08:39 PM Re: Differential Jacking
zephyr Offline
Thanks for all of your replies!
I'm much more cautious working on cars now then when I was a younger man, and make far fewer mistakes because of it. That's why I posted this question, because even after 30+ years of repairing my own cars I still don't know everything. My concern was the possibility of damaging the rear axle casting or tubes. In years past, I've never had a problem with this method on older cars and trucks. I like to slowly lower the cars weight on twin jack stands at the same time. I was never a big fan of one jack stand supporting the cars weight even if it's only long enough to move the floor jack to the other side. I have seen a single stand twist and crumple when it was used alone. Since there could be the possibility of damage, I'll just buy another floor jack and use them together. And to the person that posted:
"WTF are you trying to do?" and "Why not just jack up the frame like a normal person?" Do you really think those comments were necessary? They only diminish your credibility.
2 registered (Svtmedic, 1 invisible), 73 Guests and 317 Spiders online.
bluejay_32 218
Old_Guy_Stu 119
a_d_a_m 111
DudeAbides 95
Ponyguy 71
Moby_Vic 43
Davidzq 42
ClayBelt 42
Bangster 37
