#699704 - 05/07/05 04:12 PM Motorcraft FL820S oil filter Warning!
zephyr Offline
The following was posted on another board but it turned into a debate between Motorcraft vs Fram oil filters. What I was really hoping for was some advice on solving this problem.
I have a 1993 Lincoln Town car with 134,000 miles on it. This is not a sludged up motor and it doesn’t use oil (yet). It has a quiet engine that just recently developed a single lifter tick. You can hear it inside the car with the windows up but not from the outside. I tried two oil changes with Rislone added but no improvement. When looking at the threads in the base of a new Motorcraft FL820S oil filter that I was about to install in my wife’s car I noticed a very fine strand of metal left from the tapping of the center threaded hole (Poor quality control). All my cars take this same filter so I closely inspected the eight filters I had on the shelf and two had this hair like strand of excess metal still wound in the threads! You would probably NOT see this strand with a casual glance you must be looking for it. Then the fear set in! What if one of these strands found it’s way into the oil gallery and then into a lifter on my 1993? Using a stethoscope, I believe it’s on the driver’s side bank of cylinders. The 4.6 OHC has a hydraulic lash adjuster that is different from a push rod engines that I am familiar with. My question is: What would be the best way to confirm and isolate this noisy lash adjuster and would it be a difficult job to replace it? Any ideas would be helpful. Thanks…….
#699705 - 05/07/05 04:37 PM Re: Motorcraft FL820S oil filter Warning!
HotRod5Liter Offline
Loc: The "NetherWorld''
That sucks, just put one on my car...
The fleet:
2005 CVPI, Project "Interceptor Grand Touring'', features: 2.25'' inlet/outlet Magnaflow mufflers, Ultimate console, MP3 only head unit, MOOG rear links, MOOG cc865 rear cargo coils, FireStone Precision Touring's, Plastidipped grill, smoked headlights/corners, Mach 1 chin spoiler, custom mesh bumper inserts, Saleen inspired build number, WAY more to come, I'm just getting started!
Other current rides:
___________________________________
1988 5.0l mustang, full bolt on, minus heads/cam
1999 R/T Neon, 204,xx miles, toughest car I've EVER owned...
1993 Miata/MX5 CLEAN and fairly low miles
#699706 - 05/07/05 04:54 PM Re: Motorcraft FL820S oil filter Warning!
Buck268 Offline
Loc: Grand Rapids, MI
Is the oil filtered as it returns to the pan or as its pumped out? What side of flow would pick up the strand? I would hope its upstream of the filter elemnt, thus it *shouldnt* pose much threat. But man, now ya got me worried!
#699707 - 05/07/05 05:13 PM Re: Motorcraft FL820S oil filter Warning!
Steve83 Offline
The flow is: pan, pump, filter, engine, pan.
I have a stack of 820s that I just picked up on clearance from WM, so I'll check them out...
#699708 - 05/07/05 05:34 PM Re: Motorcraft FL820S oil filter Warning!
darkdan Offline
I'll check mine later.
Tell him www.auto-rx.com will clean his HLA MUCH MUCH better than risolene or MMO or whatever else he's going to pour into his crankcse.
I'm Dark, I'm Dan....I'm Darkdan.
98 CVPI With A Black Grill!
Southern MN's Cheapest (and 2nd worst) window tinter!
3M Paint Protection Film!
#699709 - 05/07/05 05:47 PM Re: Motorcraft FL820S oil filter Warning!
TheIndifferent1 Offline
I always run my finger along the threads to clean out any flashing left... it's pretty common. The K&N filters never have any large pieces but my finger gets minute particles on it - enough to give me a little silver ring on my fingertip where I rubbed it.
93 Crown Victoria LX
Towing Package
Phenolic piston calipers w/ AC Delco organic pads
Raybestos Super Stop Severe Duty brake rotors(slotted/cross drilled, they suck.)
Continental ContiExtremeContact 225/60r16
traction-lok rear w/ 3.27's
FRPP 9mm ignition wires
#699710 - 05/07/05 08:07 PM Re: Motorcraft FL820S oil filter Warning!
Pale Rider Offline
Steve: Dude I bought a BUNCH while I was in WM fooling around I saw them and couldn`t believe the price...PR...
2007 E-250 Super-Duty
2004 Seadoo GTX SC modded...
#699711 - 05/07/05 09:34 PM Re: Motorcraft FL820S oil filter Warning!
Steve83 Offline
Of 4 820s & 4 1As, none had any loose metal particles in the threads or the box.
#699712 - 05/08/05 01:30 AM Re: Motorcraft FL820S oil filter Warning!
ULVER Offline
Loc: Atlanta, Ga..
I'm going to have to remind myself to make note of any HLA ticks. I had it come and go. I can't remember tha last time I heard it, with my AUTO RX in there.
Signature removed. See rules.
#699713 - 05/08/05 11:38 AM Re: Motorcraft FL820S oil filter Warning!
Every filter type I've bought over the years has had some metal shavings left on it at one time or another. Aftermarket and OEM manufacturers. Is it the cause? Maybe. Just check and clean up each filter before installing it.
Alex.
#699714 - 05/08/05 11:51 AM Re: Motorcraft FL820S oil filter Warning!
Squeek Offline
Loc: Behind you
I've seen shavings on the threads of just aboot every brand of filter I've used.
The bad news is that that the oil leaves the filter through that middle hole, so anything sitting on the threads does NOT get filtered.
That's why I always make sure to brush the threads out.
#699715 - 05/08/05 01:06 PM Re: Motorcraft FL820S oil filter Warning!
1BADMERC Offline
Thanks for the heads up...
1993 GM LS
243k miles
1994 Lincoln Mark VIII
144k miles
Mercury Owners Group
This is a disclaimer:
#699716 - 05/09/05 09:56 AM Re: Motorcraft FL820S oil filter Warning!
Krusty Offline
Whats the oil route nyway? From the inner core out or the outer holes to the inner one?
Just curious. Might make a diff about worrying about shavings.
Jonathan
1999 Lincoln TC Touring, 1LNHM82W8XY######
Bridgestone Turanza LS-H 235/60/16, Edelbrock Police IAS, 3.55 RAR, 11.25" TqC,
30/18mm sways, dual exhaust, M1+Motorcraft @ 5K, 220hp/290Tq
Winter - Goodyear Ultra Grips on SporTrac Wheels
Ford Remote Start - Merry Christmas wifey!
#699717 - 05/09/05 10:11 PM Re: Motorcraft FL820S oil filter Warning!
Steve83 Offline
Krusty
Steve83
#699718 - 05/09/05 10:12 PM Re: Motorcraft FL820S oil filter Warning!
Buck268 Offline
Looks like it flows into the outter holes, down and through the filter element, and out the center hole to the engine.
1 registered (CarMon), 114 Guests and 10 Spiders online.
Bellwestern80 26
