#704628 - 05/14/05 06:46 PM HP Gains: PI Cams on a NPI Engine?
Virginiamountainman Offline
Loc: North Carolina
Did a little reading in the Archives, and came up with some interesting numbers:
Comparing a '99 P71 to an '01 P71, I am aware that the 2001 is rated at 235 HP, vs. 215 HP in the '99. According to the figures I found, a '04 or '05 PI intake would be good for about 15 HP on the ground, on the '99. PI cams, according to these numbers, would be good for about 15 more HP on the ground on the same '99. I figure that's about 35 HP at the crank, right? That would put a '99 Model with PI cams and intake (with NPI heads) at around 250 HP with nothing else done, yet the '01, with an intake that's probably good for about 5 HP less and the same PI cams is rated at 235 HP. And supposedly, that includes about 5 HP for the PI heads. If these numbers are right, how can the '99 turn about 250 at the crank with NPI heads when the '01 turns 235 with PI heads? I'm not figuring anything for HP gain from added compression, since the PI heads would be on the PI engine.
Are these numbers right? Can I take a '99 P71, add a PI intake for a '04 or '05 plus PI cams, and end up with around 250 HP at the crank? If so, that makes the '99 even more attractive over the '01, since with the '99, I would get 3.55 gears, AND a stinking TC drain plug, which is significant to me.
I'm thinking seriously about upgrading to a '99 if these numbers are good. I would think in this case that with the MM airbox/MAF, zip tube and tuner, plus a set of underdrives perhaps, I should be somewhere around 260 HP. That's the number I'm really looking for, even tho it probably still wouldn't have the torque of an LT1 350. But geared 3.55 versus 3.10 (I believe, for the 9C1), I might just be able to keep up, and stay in a P71. That's the plan anyway.
Thanks for any input you can share.
#704629 - 05/14/05 07:02 PM Re: HP Gains: PI Cams on a NPI Engine?
Tony_the_Brit Offline
Most of these upgrades produce significantly less hp than claimed. Also, you are making the mistake of believing Ford's hp claims for stock.
If you want performance then you want the PI heads.
11 Crown Vic LX Blue 151,000 m
#704630 - 05/14/05 07:59 PM Re: HP Gains: PI Cams on a NPI Engine?
BigTomZ Offline
a friend of mine did the PI intake and cams on his 97 GT. stock NPI heads. he said his dyno test showed a 26 rwhp increase even with the temp and humidity being a little higher than it was on his baseline runs. obviously im just going at his word, i wasnt there with him. i can say that i noticed his car had plenty more pull next time i rode in it.
2000 Grand Marquis LS HPP - Marauder airbox with 80mm MAF, 04 P71 zip tube, ADTR ported upper intake, SCT Xcalibrator with Reinhart custom tuning, Steeda underdrives, Gatorback belt, 3.55 gears, 11.25" torque converter, dual exhaust, Flowmaster 40's, 3" tailpipes. Alpine CDA-7998 CD/MP3 player, JL Audio 500/1 amp, JL Audio 300/4 amp, 2 Infinity Perfect 12 inch subwoofers, Boston Acoustic door and deck speakers, Stinger 1 farad capacitor.
#704631 - 05/15/05 04:45 PM Re: HP Gains: PI Cams on a NPI Engine?
JohnG Offline
Tech Admin
Loc: Socialist state of MN
The gains from PI cams ALONE are not all that great, maybe 10-15 RWHP. If you add the PI intake that nearly doubles, if you bump the shift points and rev-limiter to around 6,000 RPM, you can gain nealry 35 RWHP over the stock NPI set up (peak to peak at 6,000 rpm). This is because the NPI stuff drops power off FAST over 5400rpm, so the differences at 6000 rpm or ore are very significant.
So, the answer is: It depends.
#704632 - 05/15/05 04:57 PM Re: HP Gains: PI Cams on a NPI Engine?
Loc: North Carolina
Thanks, John. Even if it's just 10 RWHP, if you figure another 15 RWHP for the '04 P71 intake as previously stated, that still comes out to about 29.... so let's round off to 30... HP at the crank. Right? That would put a 215 HP otherwise stock '99 P71 at 245 HP WITHOUT the PI heads the 235 HP '01 would include. I still don't understand how it can work out that way, but it looks like one would actually be better off in terms of power going this way. Plus, you get 3.55 gears, a TC drain plug, and about a thousand dollar lower price tag.
I'm leaning strongly towards upgrading to a '99 and starting with these two mods, plus Time Serts or another spark plug thread remedy while I have everything torn all apart.
#704633 - 05/15/05 05:51 PM Re: HP Gains: PI Cams on a NPI Engine?
Buck268 Offline
Loc: Grand Rapids, MI
That sounds like a damn good plan, good luck with the project!
#704634 - 05/15/05 05:56 PM Re: HP Gains: PI Cams on a NPI Engine?
2000NARC Offline
Loc: Belmont Shore
Hey, John, how would you mount the NPI engine to the PI intake? Is there an adapter out there or just bolt on? Just curious, sounds like a good swap.
1996 Mustang GT, dark blue effect
19" ADR Spartans, 99 PI engine swap, flowmasters, 70mm TB,
Plenum spacer, Stalker 2 front bumper, front coilover kit
#704635 - 05/15/05 06:32 PM Re: HP Gains: PI Cams on a NPI Engine?
metroplex Offline
Loc: Motor City, USA
It sounds like VMM and 2000NARC stumbled upon a new world. Welcome to a few years ago... It's been done (PI intake on NPI heads, PI cam swap) ad nauseam. Check out Modular Depot or use the SEARCH feature on CVN.
#704636 - 05/15/05 06:58 PM Re: HP Gains: PI Cams on a NPI Engine?
Loc: North Carolina
My dear friend Charlie:
I am aware this has been done before. Well aware. I also used the 'search' function. I posed a question based on things I learned while searching that contradicted each other. And I appreciate the constructive answers I received.
#704637 - 05/15/05 07:08 PM Re: HP Gains: PI Cams on a NPI Engine?
metroplex Offline
If I had a choice between a 2001-up Panther and a 98-00 Panther, I'd take the 01-up Panther and modify that. But if I had a choice between a Ford and a German diesel, I'd take the German diesel.
#704638 - 05/15/05 07:27 PM Re: HP Gains: PI Cams on a NPI Engine?
Loc: North Carolina
Metro:
Thanks for your response.
I noticed you mentioned that same preference on your FAQ site. But since you get a TC drain plug and 3.55s on the '99, plus about 30 more HP if you do the intake and cams, I am really curious as to why you still prefer the '01 or '02, with 3.27 gears and no drain plug. I can certainly afford an '01. That's not the problem. It just looks to me like an upgraded '99 would be more car, for a little less money. Looks like about 245 HP on an upgraded '99, versus a factory rating of 235 HP on a stock '01. Which may or may not be totally accurate.
I'm going to make this move in the near future, and would appreciate any input.
#704639 - 05/15/05 10:30 PM Re: HP Gains: PI Cams on a NPI Engine?
Dextrovic Offline
Loc:
What if the German diesel was a 80's-era VW?
#704640 - 05/15/05 10:47 PM Re: HP Gains: PI Cams on a NPI Engine?
Virginamountainman - ask yourself this:
Why would a NPI head car make better power than a PI car when the only (major) differences apart from the heads are that the NPI car has a more recent air intake? This would suggest that the air intake is worth more than the PI heads which seems most unlikley to me!
How about if you added the intake to the PI car?
Something is wrong in the math here.
Incidentally, if there is any way you can afford it get an 03 - the suspension & brake changes transform the car.
One Q - by "air intake" I assume that you mean the "zip tube" - if that is so then you need a larger MAF since the zip tube is for an 80mm MAF (or some sort of adaptor).
#704641 - 05/15/05 11:00 PM Re: HP Gains: PI Cams on a NPI Engine?
JohnG Offline
Tech Admin
A base NPI eninge with PI bolt-ons (cams/intake) will never out power an "all PI" engine.
HOWEVER, ported NPI heads with the SAME cams and intake as a full "PI" engine w/ported heads will make more power. Not a lot more, but more.
MAFs, zip-tubes, and air boxes are all addative, but not in the traditional 1+1=2 way, more like the shortest distance between any two points on the globe is NOT a straight line on a flat (2D) map, but a curved one.
#704642 - 05/15/05 11:41 PM Re: HP Gains: PI Cams on a NPI Engine?
ne_plus_ultra_1 Offline
Yeah, I had the embarrassment of riding in a new 84 VW Rabbit diesel that did all of 40MPH top speed up big hills. I was about 12 years old at the time. My dad must have been embarrassed too as he sold that diesel Rabbit and bought a new Porsche the next year.
#704643 - 05/15/05 11:53 PM Re: HP Gains: PI Cams on a NPI Engine?
Loc: North Carolina
I am completely familiar with the difference between an intake and a zip tube. I was referring to the intake manifold. And yes, it appears there is something wrong with the Math. That is the reason for the post. I don't mean to call anyone out, but I have heard from one person in this thread and another person while searching that a PI intake and PI cams on a NPI engine is worth about 30 HP on the ground. Again, my point: That would equate to about 245 to 250 HP at the crank with that logic. And you are right: the numbers don't add up, since an '01 is rated at 235 HP at the crank with PI heads and intake stock.
#704644 - 05/16/05 08:47 PM Re: HP Gains: PI Cams on a NPI Engine?
What we need is an archive of posted Dyno run graphs, together with the engine specs. This would at least help people decide what to do. Matching claim V's claim is always a problem because even when they have tested the items what about the rest of the engine?
John - what do you think??
#704645 - 05/17/05 03:04 AM Re: HP Gains: PI Cams on a NPI Engine?
JohnG Offline
Tech Admin
Tony, VERY good idea, I can work on this.
#704646 - 05/17/05 03:54 AM More Myths: WasHP Gains PI Cams on a NPI Engine
Mitch Offline
Just my .02,
But if you go through all the threads on Modular Depot (a lot more 96-98 Mustang owners have done the PI intake/cam/head swap than Cvic owners)...you'll note the following:
1. The NPI intake is more restrictive on NPI power than the NPI cams. Accordingly, you will get more power out of swapping the PI intake (PI intake gaskets and black RTV) on the NPI motor than swapping the PI cams on the NPI motor. When I dyno'd my NPI motor (with 80mm MM MAF, CAI, '04 ziptube and SCT 93 octane "flash")....I was amazed to see than my hp remained flat from 4,200 to 5,000 rpm and then did a nice gradual fall down from 5,000 to 5,500. When I posted my dyno results, all the NPI veterans on TCCOA and Modular Depot laughed and said "welcome to the NPI intake".
2. If you review the cam specs of NPI vs. PI, you'll see that while the PI cams have more lift...the NPI cams have more duration. The PI cams generally make better power and the increased lift/less duration works well with the PI manifold (PI manifold by itself may lose a little low-end torque to the NPI manifold).
3. PI heads have a nominal combustion chamber volume of 42cc, NPI heads have a nominal combustion chamber volume of 51cc. PI pistons have a 17cc dish and NPI pistons have a 11 cc dish. Headswapping PI heads on a '98-00 CVic gives you a nominal 10.52 to 1 compression ratio vs. the stock PI nominal compression ratio of 9.66.
4. Despite all the ballyho about PI heads, the best 2V head on the market is still the SVO (NPI based head). The next best heads are ported NPI late model heads with oversize valves. Look at both Sean Hyland and Renegade Racing...both conclude that fully ported NPI heads outflow fully ported PI heads.
Conclusions:
Speed cost money, how fast do you want to go?
A. If you want to go fast for less, buy the cheapest, mechancially sound 1998 P71 (w/3.55s & TractionLok) that you can find (3,000-6,000) and add the following:
Used PI heads ($350)
Used PI intake ($150)
New '04 zip tube ($40)
New MM 80mm MAF ($150)
CAI ($200)
SCT tune ($175)
B. If you want a late model PI engined car you still have to do the following after you pay the much higher "intro price":
PI cars:
'01-02:
Install '04 Zip tube, MM MAF and CAI and SCT tune and still be down at least 10hp from a head swapped NPI car.
'03
Install '04 Zip tube, MM MAF, CAI and SCT tune and still be down at least 10hp from a head swapped NPI car plus being heavier (100lbs??) with less brake capacity.
'04-'05
SCT tune and still down at least 10hp from a head swapped NPI car plus being heavier (100lbs??) with less brake capacity.
Easy to see the superiority of the PI motor? Makes less power and costs more money! That notwithstanding, we should look at weight comparisons for non P71 cars too:
No worth boring everyone with silly comparisons....but leather benches and goodies all add up in weight. My 2000 CVic P71 weighs in at 4,198 on the scales with a 1/2 tank of gas, full size spare and jack in the trunk, me (190 + 10lb for leather jacket, clothes, shoes), 16" steel wheels with trim rings and center hubcaps). Per the tech official at US 41, my Cvic at 4,198 with me in it is LITE...most Marauders and loaded CVics hit the scales (w/driver) at 4,400-4,500lbs.
FWIW, there are numerous '96-'98 Mustangs running 12s with stock PI heads bolted to stock NPI shortblocks ("bolt-on" cams, PI intakes, LT headers, MAF, TB, Upper Plenum)
PI Motored cars...yeah they're clearly better....still waitintg for a PI motored Tbird to beat Johnny Langton's 12.5 in Houston!!!!
Mitch
'00 CVPI
ADTR CAI w/80mm MM MAF
'03 MAF to TB zip tube
SCT tune
#704647 - 05/17/05 10:39 AM Re: More Myths: WasHP Gains PI Cams on a NPI Engine
StevenJ Offline
Loc: Florida, USA
I am confused. Do the newer 01-05 civillian Crown Victorias come with the PI heads and PI intake stock or are you talking only about the police interceptor version? If so, why is it that it only makes 240 hp vrs. the Mustang Gt's 260 hp which uses the same motor on the same 9.4:1 compression? Are the stock exhaust really that restrictive?
Love to argue but life is too short! Or was it that the argument was too confounding and the days take forever to pass? I forget.
Car-
2003 Mercury Marauder 300B Silver Birch
#704648 - 05/17/05 10:42 AM Re: More Myths: WasHP Gains PI Cams on a NPI Engin
metroplex Offline
01-up 4.6L 2V V8s all have PI heads and PI intakes and PI cams.
The Panthers have more restrictive intakes and exhaust setups vs Mustangs, and there's also a tuning difference.
With a dynotune, some exhaust and intake work, a full PI headswap will put a pre-01 Panther into the 260 crank hp range.
NPI and PI cams have the same duration. Any difference is minimal and negligible. The PI cams have more valve lift. IIRC starting in 98-up the PI valvesprings are the same as the NPI valvesprings.
#704649 - 05/18/05 02:14 AM PI vs NPI cams
Mitch Offline
Charlie,
NPI cams: .480I/.480E lift, 204/208 duration @ .050
PI cams: .535I/.505E, 192/184 duration @ .050
Source: Sean Hyland
What's your source of information behind your assertion that PI and NPI cams have the same lift??
BTW, installed spring heights and spring pressures are different between the NPI and PI heads.
Mitch
'00 CVPI
SCT tune
#704650 - 05/19/05 12:40 AM Re: PI vs NPI cams
Charlie said that they have the same duration, not lift. He was correct about the lift.
(Of course he was wrong about the duration unless you consider the difference "minimal and negligible".)
All right guys, make it clean and no low blows...
#704651 - 05/21/05 05:45 PM Re: PI vs NPI cams
Johnny-Langton Offline
Charlie,
Source: Sean Hyland
Mitch
Mitch,I've measured both cams,and not just one set...several.
Here's the average of those sets:
Non-PI:
Intake .462" lift/201 @.050"
Exhaust .462" lift/208 @.050"
114 intake C/L
113 exhaust C/L
PI:
Intake .507" lift/200 @.050"
Exhaust .534" lift/210 @.050"
114 intake C/L
115 exhaust C/L
The duration and centerlines are so close that I'll say the slight differences seen are production tolerances.
There are alot of items in that SHM book that are incorrect.
JL
'97 Tbird LX 4.6L/4R70W-N/A
12.28 at 109.57
Ported Non-PI's
Comp Cams
#704652 - 05/21/05 06:36 PM Re: PI vs NPI cams
Loc: North Carolina
Any thoughts as to how adding PI heads to a NPI engine would affect the longevity of the engine? I would be working on an engine with 80,000 to 100,000 highway miles, either a State admin car, or a well-treated Highway Patrol edition, hopefully with relatively low idle hours. I would think that with the added compression, piston ring life could be affected.
#704653 - 05/21/05 06:43 PM Re: PI vs NPI cams
JohnG Offline
Tech Admin
VMM, no problems.
I would not trust ANYTHING SHM puts out in print etc as the "gospel", and most of it I regard as inaccurate at best or even down-right misleading in some cases.
Then again, I would not TAKE (as in for free) one of theri engines for use in anything I own either.
#704654 - 05/21/05 07:09 PM Re: PI vs NPI cams
Loc: North Carolina
Thanks, John.
#4094900 - 02/05/21 08:45 AM Re: HP Gains: PI Cams on a NPI Engine? [Re: Virginiamountainman]
FR3AK Offline
Loc: United States
Hi I just bought a 2010 crown vic pi and I had the exhaust done with muffler deletes and pipes coming out before the rear wheels but what I want to know is how much power I can expect to gain if I do a cam swap and if there is anything I should do before I do it like change throttle body and so on thanks for the help in advance I had alot of cars and bikes but never a crown vic pi
DROW A WILSON
#4094976 - 02/05/21 08:04 PM Re: HP Gains: PI Cams on a NPI Engine? [Re: Virginiamountainman]
why do you want to do a cam swap ?
comming back this fall
#4094996 - 02/05/21 10:17 PM Re: HP Gains: PI Cams on a NPI Engine? [Re: 2004_p71]
dixiebandit69 Offline
5.4 Club
Loc: Texas
Because he wants more power, duh...
Seriously, though, I think that's a bot. It's his first post, and he's replying to a thread that's old enough to get a driver's license.
Or he's a clueless rube who has a tenuous grasp of how internet searches work.
One or the other.
PROVE ME WRONG.
#4094998 - 02/05/21 10:19 PM Re: HP Gains: PI Cams on a NPI Engine? [Re: Virginiamountainman]
BlackNFast Offline
Possibly a Siberian hacker..
98 Marquis ultimate edition - Forged 4.6 2v w/Vortech v2 @ 14 pounds Max boost.
458 Rwhp and 441 FPT
Currently own:
1979 f250 Camper Special w/460 4 Barrel stock
2003 Silverado 2500hd w/ 6.0 LQ4 stock
#4095048 - 02/06/21 09:33 AM Re: HP Gains: PI Cams on a NPI Engine? [Re: dixiebandit69]
Because some people wants:
- to improve lower end torque
-get maximum effort cam for maximum aceleration
-get a loopy idle
-no idea what a cam swap is
that is why I asked DUH ....
7 registered (01boatman, smokeybandit2, gmerkt, LTC_Dave, 2 invisible), 63 Guests and 118 Spiders online.
bluejay_32 108
JeffBoudah 74
Moby_Vic 74
Old_Guy_Stu 71
Armada Master 54
DudeAbides 50
Dmblanch 46
Ponyguy 43
SocalSam 40
