#70569 - 02/04/03 10:49 AM
Re: Where is the PCM
John
Silver 2006 LX 20k Miles and counting..
**Bone Stock,.. (for now)**
Go sell crazy someplace else, we're all stocked up here.
#70570 - 02/04/03 11:03 AM
Loc: Ohio
its in la la land, ive had 2 many cold ones
2000 CV 5.4 LIGHTNING SWAP +4 psi pulley 350 HP 450 Lbs Torque
#70571 - 02/04/03 11:14 AM
Tom: Liquid's PCM article is a good one...the only things I might reinforce are:
1. Make SURE the battery is disconnected BEFORE you unhook the PCM, and don't hook it back up again until you're completely done re-installing it.
2. As with any electrostatically-sensitive device, don't handle your new chip any more than necessary. Leave it in its static-bag until you're ready to actually plug it in.
3. Make sure ALL the conformal coating (the clear plasticky-looking stuff, usually blue or green) is cleaned from the contact fingers, but be GENTLE...it is possible to scrub the printed traces right off the board if you're too heavy-handed.
4. Enjoy the new-found performance...I have no experience with Superchips, but if they're anywhere near as good as Dennis's, you will be impressed...!
#70572 - 02/04/03 11:51 AM
Loc: Ohio
Oh ! He is right!
If you dont follow this procedure, your chip may fail and or not last long as it should. Id use gloves 2.
#70575 - 02/04/03 03:25 PM
Mr. Servo:
I was under the impression you had already ordered the SuperChip...by all means talk to Dennis...also known as "DR" and "The MAN"...the vast majority of us on mercurymarauder.net have his chip and are very happy...
#70577 - 02/04/03 04:40 PM
Tom, not to take anything away from the chip idea, but if primarily what you want is the transmission re-programmed correctly, perhaps putting in a PI computer would suit? It does exactly that, and doesn't require the use of premium fuel, at a much lower up-front cost...just a thought...
#70579 - 02/04/03 06:27 PM
Loc: Orlando, Florida
You'd better ask Ronman that one.
'99 GM GS - Base Model - NO ABS, Airlift Air Springs, Draw-Tite Class II receiver, Sony 50watt CD player, 5x7 Cerwin-Vega speakers all around
#70580 - 02/04/03 07:31 PM
Oops...sorry...some of the references weren't totally clear, I must have made an ass-umption...mea culpa...but you know I meant Dennis, right?
