#792588 - 10/02/05 02:55 AM Axle Seal Leak?
Nick Price Offline
I did a burnout tonight and after I went to look at the damage, I saw that there was only one tire mark left. I've got a locking differential and I looked at the rear end and there was a slight layer of gear oil on it, coming from where the driveshaft meets the differential, all over the mufflers. Is this an axle seal leak, or something else?
Thanks
My exhaust doesn't register any decibels. It can only be measured by a seismograph.
'96 P71 - 150k miles
Full PI motor, Steeda underdrives, Bilstien HD Pros on all fours, 4.10 Traction-Lok rear
#792589 - 10/02/05 03:01 AM Re: Axle Seal Leak?
cvpi71 Offline
Mr. Kozmo
could be combination of bearing, axle, seal, etc...
R.I.P Elfy 6/06
97 PI
#792590 - 10/02/05 03:24 AM Re: Axle Seal Leak?
TechnoWeenie Offline
Loc: The perimeter
I did a burnout tonight and after I went to look at the damage...
OK.. I know "to each his own" but if you know that something you're doing could cause problems with your car... why do it?
#792591 - 10/02/05 03:31 AM Re: Axle Seal Leak?
Nick Price Offline
Actually I meant I was going to go see how well I marked up the pavement and how much tread I had left.
#792592 - 10/02/05 09:42 AM Re: Axle Seal Leak?
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
Pinion seal.
#792593 - 10/02/05 10:08 AM Re: Axle Seal Leak?
TooOldForThisVic Offline
Loc: TX
Ya, Pinion seal. These usualy don't leak till you've knocked the pinion loose. Grab the pinon flange and see if you can move it around. This will be easier with the driveshaft off, but you should be able to do it when it is on.
[--98 Crown Vic--]
->MM Airbox/MAF
->'04 Zip Tube and Ported Plenum
->10.5 CR
->3.55 FD w/ Detroit Tru-Trac
->11" (11.25"?) Mustang TC
->DR Tuned
6 registered (Rainbowpizza, bluejay_32, Rootintootin, ismann, Davidzq, 1 invisible), 74 Guests and 286 Spiders online.
bluejay_32 163
a_d_a_m 106
