#848738 - 01/08/06 01:41 AM Am I maxed out on performance?
JonW Offline
Loc: SW Missouri
My car has the following mods:
Marauder airbox and MAF
ZIP tube
colder spark plugs and thermostat
polished upper intake plenum
underdrive pullies
computer tune for 91 octane
I don't want to open the engine up, use nitrous or a supercharger, or change rear end gears. Given all that, am I maxed out on performance gains at this point?
1972 Continental Mark IV
http://themastersmo.org/
#848739 - 01/08/06 01:46 AM Re: Am I maxed out on performance?
BigJon Offline
all you can do now is lighten her up. lighter wheels, mmx driveshaft, etc..
have you had a dyno tune? do you have access to 93 octane fuel? not that it will add too much, but it'll do something.
-Current:
2001 Crown Victoria P74
-Gone, but not forgotten:
1988 Mercury Grand Marquis
1994 Ford Crown Victoria
2000 Ford Crown Victoria HPP
2004 Mercury Grand Marquis
#848740 - 01/08/06 02:14 AM Re: Am I maxed out on performance?
luv-my-2002-p71 Offline
Loc: New York
ZIP tube
underdrive pullies
Look at ADTR site (banners are above all the time) they have a 75mm throttle body and intake spacer you can add easily with hand tools. I don't have those two Items, but I think I want them.
What about your exhaust setup too?
#848741 - 01/08/06 02:52 AM Re: Am I maxed out on performance?
zwack88 Offline
Loc: Nebraska
Shorty headers with High flow cats will add HP. You can keep you stock mufflers as you probably already know they arn't the restriction unless you want some tone to it. Other then that and what luv-my-2002-p71 said about the throttle body you are maxed out. This is the reason I'm not so much in the go fast mods at this point cause once it is no longer my daily driver I'm droping in a Cobra motor. Simple bolt on's are a thing of the past for you Jon.
2000 CVPI 229k miles of greatness, Harvest Gold, glasspacks, chopped front springs, mach 1 lip, Daily/winter driver status
2000 Mustang GT Zinc yellow, most bolt-ons,waiting cams and supercharger
#848742 - 01/08/06 02:55 AM Re: Am I maxed out on performance?
you could do cams.....
#848743 - 01/08/06 03:19 AM Re: Am I maxed out on performance?
Ezbok58a Offline
Loc: Who wants to know...
Gears will make it feel faster
#848744 - 01/08/06 03:19 AM Re: Am I maxed out on performance?
texasvic Offline
I'm so fancy
Loc: Katy, Tx
But he does not want to change gears.
-Michael
#848745 - 01/08/06 03:20 AM Re: Am I maxed out on performance?
Bobert2647 Offline
Former Vic Owner
Loc: West TN
Well since he's got stock 3.27's going to a 3.55 or 3.73 is not going to be worth it. And any higher than 3.55 you are going to begin to kill highway economy.
#848746 - 01/08/06 03:21 AM Re: Am I maxed out on performance?
Ezbok58a Offline
Limited Slip then?
Bah, this is what happens when I read these things half asleep, I'm going to bed.
#848747 - 01/08/06 03:22 AM Re: Am I maxed out on performance?
Ezbok58a Offline
Not as much as you'd think, I went from 3.27 to 3.73 and my mileage is at most 3miles less than what it was before the swap.
#848748 - 01/08/06 03:25 AM Re: Am I maxed out on performance?
Bobert2647 Offline
Former Vic Owner
Loc: West TN
I personaly would go no more than a 3.55 being my car is a daily driver and I would like to keep good fuel economy numbers out of it.
#848749 - 01/08/06 03:33 AM Re: Am I maxed out on performance?
Ezbok58a Offline
So's mine, you think your daily driven CV is better than my daily driven CV? I Challenge you to a Duel!!
Pistols at Dawn!
#848750 - 01/08/06 03:40 AM Re: Am I maxed out on performance?
Embassy Offline
Actually, you will see little to no gains in return for all that $$$. Unless you have P&P heads and/or forced induction, the factory dual exhaust is sufficient.
2003 Procharged Marauder, F.I.T. #003
2004 SAP P71
The EmbassyVic:SOLD!
'01 P71: SOLD!
Keeping a black car clean is not a hobby. It's a part time job.
Support the troops.
#848751 - 01/08/06 03:48 AM Re: Am I maxed out on performance?
Bobert2647 Offline
Former Vic Owner
Loc: West TN
Even with PI heads and a mild cam and his intake mods?
#848752 - 01/08/06 09:30 AM Re: Am I maxed out on performance?
JohnE Offline
Loc: Houston
Yes, you've done most of what you can to improve your power. Go to alloy wheels, with a smaller outside diameter. Loose some wieght. Really, not much available here. In order to get more power n/a you need a higher compression ratio, ported heads and Bullet intake. A supercharger would get you there too. My advice is save your money for something that would actually net you real gains.
Forget about the cams guys. I have yet to hear someone installing aftermarket cams in a Panther and liking them. Charlie has, but complains a lot of the side effects. Our cars are heavy. Factory cams help with low end torque. Likewise the factory intake manifold helps with low end torque too. Sure you can trade the low end for hp on the upper rpm band, but it won't be much fun as a daily driver. If you really like that idea, get a stock Marauder.
Stock dual exhaust up to 2000 supports 300hp before becomming a restriction to power. Stock dual exhaust 2001+ supports more, I'm guessing around 350hp. Sure there are some slight gains in changing the exhaust in lower power applications. Is 2-7hp worth the money, effort and noise? Remember we're talking around a 2% increase in peak hp and about a 3% decrease in low rpm torque.
2000 Chestnut Grand Marquis, back to n/a.
2003 Silver Marauder - Whipple Supercharged
2002 F250 4x4 7.3L single turbo
2002 Silver Volvo S80 twin turbo
4 registered (Bellwestern80, LTC_Dave, Clark, 1 invisible), 57 Guests and 236 Spiders online.
bluejay_32 207
a_d_a_m 129
DudeAbides 123
CrystalPistol 119
Old_Guy_Stu 115
Moby_Vic 80
ford05 60
Warped9 56
Ponyguy 56
RF_Overlord 52
