Page 1 of 4 1 2 3 4 >
#943396 - 05/16/06 03:17 AM Did The Pre-98's Do Anything Better>?
ULVER Offline
Loc: Atlanta, Ga..
I want a NEW PONY! But...every once in the while, I find a cop, that asks me about my ride, and tells me he misses his ol' "Interceptor" Mine has been a good car! But I lust after the post-2000's. It just won't die yet!!! So, I areo-body on...
Seriously, did these heaps do anything better???
Signature removed. See rules.
#943397 - 05/16/06 03:27 AM Re: Did The Pre-98's Do Anything Better>?
they are faster than a 98-00 (stock for stock, thanks to the weight advantage)
They have a stronger rear suspension setup/linkage
9005/6 headlamps vs crappy 9007s
More reliable mechanical fan.
Pre-96's wont ahve their intake KabOOM!
That is likely about it.
This is probably better for the lounge
#943398 - 05/16/06 06:19 AM Re: Did The Pre-98's Do Anything Better>?
TechnoWeenie Offline
Loc: The perimeter
dont forget aerodynamics,hehe..(I'm assuming)
although I think the electrical fan is a +
#943399 - 05/16/06 08:44 AM Re: Did The Pre-98's Do Anything Better>?
GlocksterJames Offline
Loc: Aberdeen, Washington
Most officers that I've talked to regarding the aero vics compared to '98+, just seems they agreed the aero vic didn't break down compared to the newer ones.
Personally, I agree to a degree as almost all newer vehicles seem to have more problems than the older ones, from what I've seen in my experience.
#943400 - 05/16/06 08:56 AM Re: Did The Pre-98's Do Anything Better>?
metroplex Offline
Loc: Motor City, USA
The pre-98s were pretty much dogs. The 99-00 were faster due to the 3.55s, and the 01-up were much faster due to the PI 4.6 V8. The better aerodynamics and reduced weight of the pre-98s contributed to better gas mileage though.
Good point. Towing capacity is rated higher as well.
Crappy 9005/9006 vs crappy 9007s. I'd say we don't have a clear winner here unless it is E-Code H4 or HIDs, or a combination of driving lamps and headlamps.
DIdn't they have an e-fan as well? Regardless, mechanical fans have clutches that can wear out. The E-fan makes belt changes easier and has less clutter in front of the engine. The E-fan also doesn't consume as much hp to operate.
Here's one more:
Better interior and exterior fit/finish and build quality. I know Russ still says he misses his 95 CVPI and his 97 CVPI and thinks the 98-up were crap.
#943402 - 05/16/06 10:17 AM Re: Did The Pre-98's Do Anything Better>?
Virginiamountainman Offline
Loc: North Carolina
I had a '96 and two '97s, and now have a '99. I think the newer Aeros look better than the '98 up. I also agree, fuel economy is a little better. The rear suspension may be a little tougher on the Aeros, but I prefer the '99's ride by a wide margin. It handles MUCH better IMO than the two Aeros I had. I have heard some folks talk about the '98 and newer Panthers being more prone to break down, but in the year that I have had this '99, it has been totally reliable. It's in the shop today getting an alignment, fresh gear oil, and the brake fluid and power steering fluid flushed. I drive it hard at times, but I do NOT do burn-outs. Maybe that's where some of the break downs come from.
From what I have heard, the '01 and '02 models are probably the best built cars since the '96s and '97s.
VMM
#943403 - 05/16/06 10:34 AM Re: Did The Pre-98's Do Anything Better>?
Hmm the Watts linkage rear was supposed to be an IMPROVMENT vs the old 4 link. Vastly better lateral stability.
Ford downgraded the towing capacity in 97 the last of the Aero's this has been exposed as marketing crap to push you towards buying POS exploders
I may be biased to my 01 as my 93 is in much rougher shape.
The Aero also has less leg room and my knee hits the dash
2004 Crown Vic LX SOLD!!
#943404 - 05/16/06 10:48 AM Re: Did The Pre-98's Do Anything Better>?
Loc: North Carolina
There ain't no denying my '99 rides and handles a whole lot better than the three Aeros I owned.
VMM
#943405 - 05/16/06 11:01 AM Re: Did The Pre-98's Do Anything Better>?
32VMarquis Offline
So I must say if your have to get an Aero bodystyle, you can never go wrong with a pre-98 grand marquis! Post-98 interior with weight savings of pre-98 and I just think the way the tail lights are on them is awesome! Now I just have to find out how I can get a marauder front clip on it! I love the look of that front end~!
1995 MGM Champagne with tan leather.
This thing needs cosmetic work but what can you expect for 200 bucks~ But it runs great!
#943406 - 05/16/06 11:49 AM Re: Did The Pre-98's Do Anything Better>?
Loc: North Carolina
One more thing: While I have no regrets at all about buying this '99, if you want the most bang for the buck, find a NICE unmarked '96 or '97, catch up on all the maintenance, and go first class on your ongoing maintenance. I doubt that it would lay down on you before you finally get tired of it.
I passed up a dark blue '97 a while back with 40,000 miles. It was a tough decision.
VMM
#943407 - 05/16/06 12:15 PM Re: Did The Pre-98's Do Anything Better>?
observer Offline
"They have a stronger rear suspension setup/linkage"
"Good point. Towing capacity is rated higher as well. "
i have noticed alot of yellow 98+ cabs here have the older (upto 97)non watts link rear end. (Yes I can easily see it when following behind.) i even mentioned it to a friend in the pass seat who knew nothing about cars and he could clearly see it
they either put a 98+ body on an aero frame or a older axle on a 98+ car. prob just the axle
i like my aero because it does not cause as much attention. and the attention gets less and less with each passing year
1997 P71 145K miles
#943408 - 05/16/06 01:10 PM Re: Did The Pre-98's Do Anything Better>?
I was comapring a 2.73 equipped -97 to a 98-00 2.73 car (which I have personally compared in the past ) The aero was without a doubt quicker.
My aero, after 3.27s + Duals were instaled, was also quicker than a 99 CVPI equipped with 3.55s. So pffft.
Fine i will correct it:
Crappy 9005/6 vs crappier 9007
Yes, aeros have both an e-fan and mech windmill
The clutches do wear out, but unlike the e-fan it will not completely fail and leave you stranded (bad experience in our old 98 town car), it's effectiveness fades. Snaking the belt over the fan is nothing, it may take a person an extra minute or so...
#943409 - 05/16/06 01:44 PM Re: Did The Pre-98's Do Anything Better>?
PlainOldDave Offline
Loc: Oak Ridge, TN
Cornering lamps and the way-cool Lighting Package, not to mention I think the aeros are better looking cars than the 1998+; if I had wanted a Mercury, I would have bought a Mercury. I still don't understand why the Lighting Package was done away with for 1998...
Mine: 1998 P73, 244K miles.
Hers: 1996 P74, 165K miles.
#943410 - 05/16/06 01:49 PM Re: Did The Pre-98's Do Anything Better>?
Bobert2647 Offline
Former Vic Owner
Loc: West TN
Umm Derek just to clear things up it's 95-97 aeros have both mech, and electric fans. Granted you can't fo wrong with a mech fan. Electric does free up a little HP and MPG.
#943411 - 05/16/06 01:50 PM Re: Did The Pre-98's Do Anything Better>?
metroplex Offline
The 98-up have a "fail safe cooling system" that SUPPOSEDLY allows sub-50 mph operation for 50 miles...
My Vic doesn't need the e-fan to run constantly to keep the ECT within norm. With enough airflow (highway driving) the coolant is kept cool.
The 96-97 vs 98-00 in terms of performance is indeed an easy one: the 98-00 are heavier and do not have much horsepower over the 96-97.
#943412 - 05/16/06 06:14 PM Re: Did The Pre-98's Do Anything Better>?
mrbear5300 Offline
professional grade
Loc: BUF
This is an interesting thread. I thought it was just me that liked the pre 98's looks. I really dislike the tail lamp set-up on the 98+ panthers. The long narrow tail lamps on the pre 98 GM's are cool.
#943413 - 05/16/06 06:33 PM Re: Did The Pre-98's Do Anything Better>?
JWhittaker Offline
Loc: Seekonk, Ma
How bout the profile on the Aero's way way better than the 98 plus cars I love the way my 92 LX looks compared to the 2000 profile.....I mean jez what kind of springs did they put in the front the thing is freakin tall. The 2Ks ass end is way tighter than the 92 but as for the 2.73's you can keep em there coming out as soon as I can find somebody to do them, I would try it but never done rear end gears before.. The 98 plus brakes are supposed to be better but before I got the new car the 92 has all new rotors and pads and that thing stops awesome, pretty much always has but with new parts AWESOME, I think the 2K has warped rotors or something, they said they were turned before I bought the thing in Oct. its got the side to side steering wheel thing when you hit the brakes fairly hard, Keep the Aeros Alive!!
2002 CV LX Sport
Speed Bleeders installed with the new brakes!10/07-brakes 85K at the time
http://www.flickr.com/photos/25029145@N06/2382004080/
#943414 - 05/16/06 07:11 PM Re: Did The Pre-98's Do Anything Better>?
99_03PantherS Offline
Loc: NW side Chicago
I like how the aeros feel more nimble while taking turns. the 98+s look like they have larger trunks tho.
Jason G.
'06 Towncar Designer
'07 P71 SAP
'78 Continental
'98 Mark VIII
#943415 - 05/16/06 07:15 PM Re: Did The Pre-98's Do Anything Better>?
Danny_Boy Offline
Loc: Franklinville NY
I'd take a 98+ over a areo anyday ! I had a '97 CVPI and it was not only a dog but only lasted me like two months before the motor whent
#943416 - 05/16/06 07:29 PM Re: Did The Pre-98's Do Anything Better>?
BigJon Offline
i have owned a box, aero, and now my whale.
my box, i beat the crap out of it and it never skipped a beat.
my aero had great gas mileage. sometimes i would hit the low- mid 30 mpg.
my whale is the best yet, though i don't beat it up because i am still worried of the intake crossover. i should just replace that.
-Current:
2001 Crown Victoria P74
-Gone, but not forgotten:
1988 Mercury Grand Marquis
1994 Ford Crown Victoria
2000 Ford Crown Victoria HPP
2004 Mercury Grand Marquis
#943417 - 05/16/06 07:34 PM Re: Did The Pre-98's Do Anything Better>?
BigJon Offline
yes, my aero was a dog too, forgot to mention that.
-Current:
#943418 - 05/16/06 07:41 PM Re: Did The Pre-98's Do Anything Better>?
Ezbok58a Offline
Loc: Who wants to know...
Aero's are very unstable when they exceed 100mph.
But they look good (Big tail lights rock!) and are lighter than the current Vics and GMs. However the newer ones make up for the weight with increased power.
#943419 - 05/16/06 09:00 PM Re: Did The Pre-98's Do Anything Better>?
JWhittaker Offline
Loc: Seekonk, Ma
That's it I decided I'm keeping my aero for safe keeping in case somebody slams into me in the 2K..... That way I can put the 92 back on the road
2002 CV LX Sport
#943420 - 05/16/06 09:16 PM Re: Did The Pre-98's Do Anything Better>?
metroplex Offline
The 98-up are stable above 100 mph. The only way you know you're going too fast is that the trees are going by kind of fast
#943421 - 05/16/06 10:22 PM Re: Did The Pre-98's Do Anything Better>?
Michigansquadcar Offline
Loc: Southeast michigan
The Aeros use plug wires instead of the COPs that go bad. You can buy a set of wires for the price of 2 cops.
#943422 - 05/16/06 11:05 PM Re: Did The Pre-98's Do Anything Better>?
True, but COPs do look much 'cleaner'
#943423 - 05/17/06 12:45 AM Re: Did The Pre-98's Do Anything Better>?
Taxman100 Offline
Loc: Ohio
My old 94 rode more smoothly, and had much better road isolation, which is more my bag than handling.
Also have much better carpeting. My 02 has much better climate control switches (no more floppy slider issues), and has much better power.
2011 Volkswagen Routan SE w/RSE #2 - 103K, #1 Totaled 8/14
2002 Grand Marquis LSE - 15k
1967 Galaxie 500XL convertible - 36k of old school
#943424 - 05/17/06 03:26 AM Re: Did The Pre-98's Do Anything Better>?
Loc: The perimeter
have to agree with the fit+finish being better on the aero's, I had a '95(best of the aero's, I think)and it was MUCH quieter than my '98, PLUS, my '95 had 160K miles on it, and drove/looked like new, my '98 with 60K miles on it has more "nuances" than a car with almost 4x the mileage.
#943425 - 05/17/06 09:17 AM Re: Did The Pre-98's Do Anything Better>?
BMFer Offline
I'm your huckleberry
Loc: 30106
If that's what you think, you were in an aero with a very worn out suspension when you decided that. My aero is as stable above 100 as my 94 Z-28.
Aeros are far more aerodynamic. They are also lighter, faster (top-end), and get better gas mileage. I actually prefer the 4 link aero rearend over the watt-link 98+rear. Try cornering hard at high speeds over bumps in a whale and you'll see why, once you get the airbag pushed out of the way.
There have been many improvements made over the years on the whales though. I would gladly take most of them, save the watt link rearend and the body, in my aero chassis. I have not seen where either one was any more or less dependable than the other though.
'13 Coyote 5.0
#943426 - 05/17/06 09:53 AM Re: Did The Pre-98's Do Anything Better>?
True, you dont have to spend 1-2 hrs routing them when replacing like the wires.
But, With the cops: When replacing the intake you have to remove all of them. On reinstallation of the intake, they give you new screws that hold them down that are a pain. The wires can stay in place and not cause any interference. A time saver
#943427 - 05/17/06 10:43 AM Re: Did The Pre-98's Do Anything Better>?
Bobert2647 Offline
Former Vic Owner
Loc: West TN
Yup, when I did my intake swap I just left all the wires as is. The only thing I don't like with the coil packs is that they are in a bad place. Why couldn't Ford have put them a little more out of sight. And have one do one side and one do the other without having wires cross over the alternator.
#943428 - 05/17/06 10:52 AM Re: Did The Pre-98's Do Anything Better>?
metroplex Offline
The COP coils fail very easily and are in a bad place (water can pool in there). They are also very expensive
#943429 - 05/17/06 12:22 PM Re: Did The Pre-98's Do Anything Better>?
Loc: Oak Ridge, TN
If you're running 2 way radio in your Panther, COPs are the only way to fly. Plug wires act like little radio antennas.
#943430 - 05/17/06 03:50 PM Re: Did The Pre-98's Do Anything Better>?
Rexem Offline
Zamboni Pro
Loc: Roseville,MI
It was the front end that sold me on 98+ vics, the headlights on those aeros are blahh.
All stock drivetrain - Tint: 5% rear 15% front
#943431 - 05/17/06 04:27 PM Re: Did The Pre-98's Do Anything Better>?
Bobert2647 Offline
Former Vic Owner
Loc: West TN
Pfft, thats nothing. Aero Vic's and Marquis can both swap to the 98+ front clips.
#943432 - 05/17/06 04:31 PM Re: Did The Pre-98's Do Anything Better>?
1FSTCAT Offline
Loc: Cincinnati, OH
I definitely like the look of the 98+ better. They also have better brakes, and I think the watts link rear is an improvement on uneven or rough terrain. I like the way they ride and handle better than the 97-.
However, the aero is more reliable (no COP's to randomly fail), mechanical fan, and gets better gas mileage.
I decided to get rid of my 99 and go back to a 96, when I realized that I could have a similar car for half the money and it did most of what the 99 would do, if not better.
I sold my 99 for $5000, bought the '96 for $1000, repainted it, put on the 98+ brakes and 16" wheels, rebuilt the transmission, and still have less than half of the $ investment than the '99.
--Ed
1987 Mercury Cougar - 306, Powerdyne supercharger, T-5, 385 RWHP, 420 RWTQ.
1991 Crown Vic Ex Police - 460, C6, 98+ front brakes. 14.15 @ 97.5 MPH. Needs much tuning still!
2007 Ford Expedition (Daily Driver)
#943433 - 05/17/06 05:23 PM Re: Did The Pre-98's Do Anything Better>?
dragoncvpi Offline
Loc: florida
I generally like the 98 plus better, although, BMFer's ride looks good. I would think with the right bushings, etc., the watts would be better than the 4 link. I like the COP arrangement too better. Just my 2 cents.
Gone but not forgotten
#943434 - 05/17/06 06:43 PM Re: Did The Pre-98's Do Anything Better>?
Ezbok58a Offline
I did autocross the 04, and despite some understeer it went through the course very well at relatively high speed. Would I do that at a higher speed? probably not, would I try it? No.
#943435 - 05/17/06 08:14 PM Re: Did The Pre-98's Do Anything Better>?
LTDteether Offline
Name that tune:
Now the boys all thought I'd lost my sense
And telephone poles looked like a picket fence
They said, "Slow down! I see spots!
The lines on the road just look like dots
'99 GM GS HPP.
#943436 - 05/17/06 09:35 PM Re: Did The Pre-98's Do Anything Better>?
BMFer Offline
Loc: 30106
...And Daddy said "Son, your gonna drive me to drinkin' if you don't stop drivin' that hot rod Lincoln."
That was too easy.
Honestly folks, with the age that aeros are now, it's really hard to call them more reliable... maybe when they weren't 10 + years old, but I still prefer them. And don't get me wrong on the watt-link suspension- I love it on smooth asphalt, but I've nearly lost several whales (even new ones) on washboard curves playing too hard. I think the extra little bit of give in the 4 link aero rear suspension can be a saving grace at times, and I personally like the ride quality better.
In a perfect world, I would choose an '01-'02 drivetrain (save the rearend) in an aero body, with whale front brakes, steering gear & master cylinder.
'13 Coyote 5.0
#943437 - 05/17/06 10:05 PM Re: Did The Pre-98's Do Anything Better>?
Hot Rod Lincoln , Heard that song EVERYDAY on the radio in High School. I came from a hick town
#943438 - 05/17/06 10:22 PM Re: Did The Pre-98's Do Anything Better>?
BMFer Offline
Loc: 30106
And what exactly is wrong with coming from a hick town?
'13 Coyote 5.0
#943439 - 05/17/06 10:27 PM Re: Did The Pre-98's Do Anything Better>?
You have to listen to Hot Rod Lincoln everyday
#943440 - 05/17/06 10:28 PM Re: Did The Pre-98's Do Anything Better>?
BMFer Offline
Loc: 30106
It beats the hell out of the rap I listen to every day (at every stop sign & traffic jam.)
'13 Coyote 5.0
#943441 - 05/17/06 10:31 PM Re: Did The Pre-98's Do Anything Better>?
Very true.
#943442 - 05/18/06 04:01 PM Re: Did The Pre-98's Do Anything Better>?
Mileaway Offline
Loc: Sacto. Calif.
Very true.
Got that right. X2
#943443 - 05/18/06 05:32 PM Re: Did The Pre-98's Do Anything Better>?
Bobert2647 Offline
Former Vic Owner
Loc: West TN
Gotta like the 2-tone interior color 95-97's got.
#943444 - 05/18/06 05:51 PM Re: Did The Pre-98's Do Anything Better>?
mrbear5300 Offline
professional grade
Loc: BUF
Its awsome! Gotta love my puke tan and poop brown dash!
#943445 - 05/18/06 08:26 PM Re: Did The Pre-98's Do Anything Better>?
Bobert2647 Offline
Former Vic Owner
Loc: West TN
Ohh please that better than being all poop brown.
But this is good lookin...
Or this...
Both are older pics. Right now in the 96' my wood trim has been removed for painting for a special project.
#943446 - 05/18/06 10:21 PM Re: Did The Pre-98's Do Anything Better>?
mrbear5300 Offline
professional grade
Loc: BUF
I actually wish it was all poop brown. The lighter color looks like peanut butter. Everything else, including my seats, are that wierd color. Only my steering wheel/column and dash top are dark brown, which I think is a nice color.
#943447 - 05/18/06 10:30 PM Re: Did The Pre-98's Do Anything Better>?
GhostRider Offline
I know how you feel. I long for a new CVPI (04+) but I look at my 97 and think for a second and keep it.
-Tim
#943448 - 05/18/06 11:55 PM Re: Did The Pre-98's Do Anything Better>?
johnrmcnary Offline
well, the 03+ definately has a couple advantages....
rack and pinion steering is nice.
even bigger brakes than '02
steering wheel stereo, a/c and cruise buttons (reaaaaly nice since after I broke my right arm I couldn't reach the stereo buttons)
and I haven't had any problem with fit and finish... after 65 k everything is just like new
Some days, it's just not worth chewing through the leather straps
#943449 - 05/19/06 12:01 AM Re: Did The Pre-98's Do Anything Better>?
DuceAnAHalf Offline
Loc: Pinellas Park, Fl.
You can see the watts link from behind the car? Thats interesting since the Watts link in on top of the front side of the axle, the cars around you must have a lot of lift in the rear.
My 97 with good shocks is rock steady at 130 MPH. With the blown out shocks 115 started to get scary.
#943450 - 06/19/06 03:12 AM Re: Did The Pre-98's Do Anything Better>?
Cliff Offline
I like both the Aeros and whales. I'm torn between getting a '96-97 Aero with the lightness, a '99-00 with 3.55 gears or an '01-up with a PI engine. Then again it be nice to have an Aero with both a PI engine and 3.55's
Stopped by Copcarsonline today (they were closed) and went for a short look. Mark has one Aero in great shape, a black/white 9C1 Caprice and the rest are whales.
#943451 - 06/19/06 09:59 PM Re: Did The Pre-98's Do Anything Better>?
rbbassett Offline
Loc: boston MA
no one mentioned the audio systems?
92-97? had the awesome (in my opinion) high end audio systems with JBL (?) amps/sub. i was pissed when i found out my high end radio for the 01 had no external JBL amp or subwoofer. 98-present? don't have subwoofer available, even though the hole in the rear deck is still there. dammit.
oh yeah, and the 92lx i had was a smoother ride but my 01lx handles better. 92 seemed quicker, but i tell you when i peg the pedal on the 01 (which is rare), that mofo takes off like a friggin rocket. chirps the tires into 2nd on dry pavement (and fairly new tires)
2001 Green Crown Victoria LX HPP, 60k miles.- traded for minivan. /sigh/
2 registered (RipWixomAssembly, Swirlsound), 104 Guests and 12 Spiders online.
Traffic22 15
