#977812 - 07/07/06 05:37 PM Need trunk measurements ASAP!
Team Taxi Offline
Hey guys,
I'm working on the custom audio system for our 2000 Crown Vic (if you're unfamiliar with our project, click here: https://www.crownvic.net/ubbthreads/showflat.php?Cat=&Board=performance&Number=1146657&page=2&view=collapsed&sb=5&o=365&fpart=1).
I need the measurements of the area of the trunk UNDER the rear deck, but the car is an hour away right now. Can someone measure the LWH for me? I would really appreciate it.
#977813 - 07/07/06 06:48 PM Re: Need trunk measurements ASAP!
copperspine Offline
50 wide 21 deep 11 high.
But that was with the trunk opened, the trunk lid arms will likely need clearance room on each side.
1998 P71, Silver soon to be dark cherry. Looking for denim front seats, drivers door panel and air bags!
#977814 - 07/07/06 07:07 PM Re: Need trunk measurements ASAP!
Team Taxi Offline
Thank you very, very much.
#977815 - 12/15/06 10:57 PM Re: Need trunk measurements ASAP!
Team Taxi Offline
Does anyone know the dimensions MINUS the trunk lid arms?
#977816 - 12/15/06 11:18 PM Re: Need trunk measurements ASAP!
JCG1 Offline
Loc: Chicago
Actually, he measured the area BETWEEN the hinge supports (that extend from the floor of the shelf to the underside of the rear cowl area)
That's 50"
There is an ADDITIONAL 6 1/2 " (about) clearance on each side of the supports (measured to the inside of the fender)
HOWEVER
THE HINGES FULLY TRAVEL TO THE BOTTOM OF THE SHELF
AND THAT TAKES UP 2" MORE ROOM ON EACH SIDE ON THE INSIDE OF THE SUPPORTS.
So unless you eliminate the hinges and their travel, you only have 46" on that shelf to work with - not 50".
You have 6+" of dead space on the outside of the support - on each side, so if you could eliminate that whole hinge assembly (including the truss supports) you'd have about 63", inside fender to inside fender.
Former Ford Projects: 1967 Mustang w/transplant 351W : 1984 302 T-Bird : 1987 5.0 T-Bird : 1989 5.0 Mustang : 1992 5.0 T-Bird : Current: 2000 CVPI
Renegade Racing 4.6 SOHC: Cobra Crank, Manley Rods, Coated Diamond Pistons 10.5:1 comp w/valve reliefs, PnP npi heads, PI intake, Comp Cams, 70mm TB, MM Airbox/80mmMAF/04 Zip, 190lph walbro, FRPP shortys, custom 2.25 duals, Xcal2, Jmod RoadmasterTranz, Dirtyd0g TC.
14.46 @ 95.59 / 14.50 @ 95.91 tuned by Darrin at BC Automotive
Watch a 14.58 @ 94.13 Vid by DJChicago HERE
#977817 - 12/16/06 03:32 AM Re: Need trunk measurements ASAP!
Steve83 Offline
If you're building a box OUTSIDE the trunk to be placed in it later, remember to consider the trunk opening size, too.
#977818 - 12/16/06 01:07 PM Re: Need trunk measurements ASAP!
Team Taxi Offline
Is the '98 trunk the same as the 2003?
Edited by Team Taxi (12/16/06 01:09 PM)
4 registered (ironmarinebill64, CrownBen, magic, 1 invisible), 78 Guests and 288 Spiders online.
bluejay_32 165
Old_Guy_Stu 98
a_d_a_m 94
Moby_Vic 55
CrystalPistol 50
TheCableGuy 47
RF_Overlord 44
Ponyguy 39
