Page 2 of 2 < 1 2
#1932525 - 12/12/09 01:49 AM Re: HVAC controlls auto swap possible [Re: GM_Guy]
2vmodular Offline
Loc: New England
you might be able to use the electronic automatic temperature control (EATC) setup from a later crownvic in your box body crownvic. i've been running my retrofitted car with a standalone eatc setup for many years now without any scp databus connections.
has anyone tried physically fitting the electrical blend door actuator from a 1990's crownvic into a pre-1990 car?
http://www.p71interceptor.com/eatcswap
Visit my website for info on adding good stuff to your crownvic:
#1962344 - 01/22/10 05:00 PM Re: HVAC controlls auto swap possible [Re: 2vmodular]
Missed your followup 2V, I want to stick to manual controls in my box. Tommorow I might hit the wreckers and see if I can locate a mustang control and a 95+ cv out there to rob the vacuum selector from and do some experimenting. I'll see if anything is ripped apart enough in the boxes to get pics of the blend door setups.
Alex.
#4107308 - 05/03/21 11:11 AM Re: HVAC controlls auto swap possible [Re: AOD]
Justin McCarter Offline
Loc: Fredericksburg VA
Originally Posted By AOD
Long story short, avoid if you can, unless you do some significant homework with the wiring diagrams.
Wire: http://www.supermotors.net/registry/1538/56458
Vacuum: http://www.supermotors.net/registry/1538/56459
HVAC: http://www.supermotors.net/registry/1538/56465
~Adam
i'm working with an 89, with auto temp, if you have the diagrams for that let me know, otherwise i may just purchace a single vehicle 3 month license next month
it was working the first day, ac still cycles, but only comes out of defrost only now
daily driver FORD F350 king ranch, 8' bed 6.4l diesel, spartan 310 tune, egr delete, 5" exhaust...
!!deceased!!! 1990 Crown vic GT A9L MAF computer conversion 347 stroker, F303 cam, T5 5speed trans. big brakes , disk rear._- Stock heads and intake [email protected] 4k [email protected] 2-3.4k !!!deceased!!!
http://www.cardomain.com/id/mccarterjg
#4107342 - 05/03/21 02:47 PM Re: HVAC controlls auto swap possible [Re: Justin McCarter]
Sounds like a vacuum leak. Look for a busted hose somewhere.
1988 CVLX Formal Roof (Love Boat) POTM July 2019 & Aug 2020, 55K
#4107454 - 05/04/21 09:59 AM Re: HVAC controlls auto swap possible [Re: Old_Guy_Stu]
i ended up buying a year for 30$ not too bad.
the black vacuum line to the thermal blower lock out switch was broken, fixed that found yellow vacuum tube to "full panel" actuator, and had everything working for about an hour until the green tube from the tbl switch broke just sitting there, still have vent and ac.
found the tbl switch is bad even when hot no blower function on floor. will bypass that switch electrically and vacuum'ly,
spot of good news the afc "sensor" has a date on it from year 2000 and i blew out the debris in the afc sensor feed tube blockages.
Page 2 of 2 < 1 2
6 registered (Lance01, 67Comet, magic, 85GT, a_d_a_m, 1 invisible), 77 Guests and 206 Spiders online.
CrystalPistol 209
JeffBoudah 61
