#4072492 - 07/31/20 02:54 PM build advice
symonds86 Offline
Loc: NY
hello new member looking for advise I have a 73 f100 i built last winter with a 2011 cvp71 front subframe, engine, trans, and most of the wiring harness running cv bcm and ecu with egr, evap and catylist delete. its stock parts other then long tubes cai and j mod. i want to build an engine this winter i have built many sbf and sbc but new to building a modular engine. i would like 350- 400 hp if that realistic, and i am thinking i would like to stay na. i have a complete engine from a 2006 explorer i was going to use the block from to save weight. i was thinking aftermarket heads cams and upgraded internals but unsure on the best route. this is a street truck i drive often and want it to stay streetable. any suggestions on what parts to use or steer away from would be great
wrecked 2008 p71 transplanted into 73 f100
#4072522 - 07/31/20 09:09 PM Re: build advice [Re: symonds86]
ClayBelt Offline
Loc: Leon County
Pretty much the only way I can think of you’ll hit those power numbers is a trick flow top end on a 5.4 short block.
There’s a right way, a wrong way, and a janky way to fix something; I don’t usually have the brains or the money to pick the right way.
2001 Chevrolet Tracker LT “Featherbrick” - 6/2016-10/2016 - SOLD
2005 Toyota 4Runner SR5 “Panzer” - 8/2016-4/2018 - SOLD
1966 Ford Thunderbird “Fordy McFordface” - 11/2016-2/2020 - TRADED
2005 Buick LaCrosse CXS “Jumba” - 2/2017-2/2018 - SOLD
2010 Mercury Grand Marquis LS “Touge Sofa” - 4/2018-?
1990 Mazda Miata “Little Boy” - 5/2019-10/2019 - SOLD
1986 Ford Mustang SVO “Touge Fox” - 2/2020-11/2020 - TRADED
1978 MG Midget 1500 - 11/2020-?
#4072600 - 08/01/20 12:26 PM Re: build advice [Re: symonds86]
speedfreak Offline
Loc: Massachusetts,USA
At the crank or at the wheels?
Marty tuned 2006 LX Sport: enlarged Air Box intake tube to 4" and sealed to radiator support, stock "Sport" front spring/ arnott HD rear air bags, KYB PI spec gas-a-justs all around, 28.5mm front sway bar, 21mm rear sway bar (both with poly bushing), 3:27 locker rear, Heinous rear control arms, Metco watts link, SW cat back w/ chambered mufflers, 20% tinted windows, drilled/slotted rotors, black AMR rims 19"x8.5 245/45/19 front, 19x10 285/40/19 rear, SVT badge on decklid, Sony head unit, kenwood 6x8s@ 45watts, jbl 12" sub @500W
#4072628 - 08/01/20 06:21 PM Re: build advice [Re: symonds86]
"junior"(now MrVic2004) built a high compression motor and it got to 356 rwhp
It was stroked and had many parts to it...
http://www.supermotors.net/registry/26104
#4072650 - 08/01/20 09:54 PM Re: build advice [Re: symonds86]
symonds86 Offline
Loc: NY
I would like 350 rwhp, I'm not against a stroker as long as it runs pump gas. It will be a long term build as I
Just bought front coILovers and rear coilovers for it and I have a 2018 mustang irs to put in over the winter. So after that stuff it will be ready for more power.
#4073052 - 08/04/20 09:19 PM Re: build advice [Re: ClayBelt]
and it,s totally doable !
made 390-382 NA on my 5,4 2 V
Best time 13.079 @ 105 1.8 60'
Hunting for flat 12's in 2023 !
#4073118 - 08/05/20 08:01 AM Re: build advice [Re: symonds86]
symonds86 Offline
Loc: NY
thanks for the reply's i am trying to do my research, biggest hurtle is the ecu, what sensors to use, and the tuning end of it. i have always done carbs on any higher hp engine builds i have done. I am unsure of any tuners in upstate ny area
#4073122 - 08/05/20 09:50 AM Re: build advice [Re: symonds86]
ClayBelt Offline
Loc: Leon County
If you use all the vic electronics Marty can remote tune these cars pretty well.
#4073124 - 08/05/20 10:33 AM Re: build advice [Re: symonds86]
symonds86 Offline
Loc: NY
thats great to know i want to stay with all the vic stuff because i already have it working in stock form now. I have senn his name alot on here whats his website i would like to contact him and see what he says
#4073134 - 08/05/20 11:09 AM Re: build advice [Re: symonds86]
HavocMan Offline
Loc: NJ
Marty at MO's Speed Shop:
www.mosspeedshop.com
2011 CVLX
#4073680 - 08/10/20 10:35 AM Re: build advice [Re: symonds86]
symonds86 Offline
Loc: NY
thanks after doing more research picking some professional brains, I am thinking supercharging might be the way to go. Having never done it before i was leaning away from it but bang for your buck and for my goals it seems to make sense. I am thinking the tork tech system, with an eaton. I know it wont be any cheaper when all said and done but I am limited in room in the front of the engine. I still have alot of things to look into though before i decide on a route to go. thanks for the help so far
#4073684 - 08/10/20 11:24 AM Re: build advice [Re: symonds86]
72P71 Offline
Loc: Georgia
Another route that's not as much $$$ is an STS turbo system. Look up Powernation Crown Vic Turbo. They have a pretty good video with lot's of information on parts used on their website.
I think they made 368 rwhp with only 8 psi...
0 registered (), 109 Guests and 11 Spiders online.
speedfreak 27
PrincePolaris 20
Traffic22 15
