#4089208 - 12/28/20 02:41 PM
White smoke from exhaust
Loc: Florida, US
1998 MGM. I've heard head gaskets are very very uncommon on our cars. I had an intake leaking into the valley and was told here and other places it was likely a failing intake. So I changed the intake. It's more responsive but I'm still getting white smoke although the leaking coolant into the valley seems to have stopped. Is there anywhere else this could be leaking into the cylinders?
I have white frosted spark plugs on at least cylinders 1 and 4, didn't pull the others although I probably should have. Starting the car with the coolant cap off does not perturb it like exhaust gas was getting in, and the oil does not have water in it or viceaversa.
Thanks!
#4090746 - 01/08/21 11:29 AM
Re: White smoke from exhaust
[Re: joedogg]
Loc: The Desert
Do you have low compression/power, overheat, or any other issues other than the smoke?
#4092602 - 01/21/21 04:06 PM
[Re: 2010mgmUltimate]
Loc: Florida, US
The power seems alright. I don't have a good compression tester and the harbor freight one I do have doesn't have the right adapter. Any advice for compression testing it right?
#4092610 - 01/21/21 04:47 PM
[Re: joedogg]
Most chain FLAPS will have a compression tester in their Loan-a-Tool program.
'03 Mercury Marauder (The Blackbird) Trilogy Motorsports supercharged #61 Too many mods to list / Driveway Queen
'04 Grand Marquis LS Limited Edition (Spruce Green) Daily Driver (Thanks, Adam!)
'00 Grand Marquis GS (Silver) Rotted frame and broken transmission crossmember Being resurrected...slowly.
#4092658 - 01/21/21 08:48 PM
[Re: joedogg]
Loc: Charlotte, NC
Did you ever change out the intake gaskets? To me it sounds like you're burning coolant. If the exhaust is a thick white, smells like burning sweet, and your coolant levels are dropping, your car is definitely eating it up as a snack. From what I know, '98 MGM uses a single exhaust, so unbolting the Y-pipe and checking which side the white smoke comes out can help narrow it down.
I had this problem last summer with some mostly disintegrated gaskets (and part of an intake manifold port). Replaced the gaskets and remedied the intake with some RTV. Hasn't leaked since.
Edited by YoungP71dude (01/21/21 08:54 PM)
Easily the youngest Panther owner on the planet. 2004 P71 - 8/12/2019-present - Teenager-owned and maintained Ex-Sheriff Car w/ 87K miles DIY 2.5" Catback Dual Exhaust; Posi 3.73 & Manual on the wishlist Noico Sound Deadening $370 Maaco Black Paint Job (self prep work) Plowed by a minivan and still running better than ever. Your imagination, DIY skills and wallet are the only limits when it comes to modifying a Panther car.
#4092710 - 01/21/21 11:32 PM
[Re: joedogg]
Loc: SoCal High Desert
1998 MGM. ..So I changed the intake. It's more responsive.. Is there anywhere else this could be leaking into the cylinders? What replacement intake did you use? I have white frosted spark plugs on at least cylinders 1 and 4, didn't pull the others although I probably should have. Starting the car with the coolant cap off does not perturb it like exhaust gas was getting in, and the oil does not have water in it or viceaversa.
Thanks! If you have nPI heads (standard on your car) and you used a PI intake, you quite possibly have a leak between the head's water passages and the end cylinders (1,4,5,8).
'95 P71, 5xx,xxx miles, Rebuilt tranny, 2.73. Lives as a cab, and will die as a cab. (Died-FrontEnder) '96 P71, 640,xxx on original drivetrain. (Now parts car - T-bone & roll)(You should see the roof - A,B & C-pillars chopped on driver side) New to list: '96 MGM (Nice! @ 35x,xxx), '97 CV P71, '98 CV P71, '00 CV P71, 01 P71 (2 of 'em) '03 CV P71 (Nice so far) (All Ford Zinc Yellow w/Black decals & trim) And the list is growing........... Taxicab mechanic: I HATE DRIVERS!
