#4098732 - 02/23/21 06:22 PM
Re: U-joints for driveshaft swap
[Re: 66lincoln]
Loc: NH
I would grab a pair of dial calipers and do some measuring to figure out what you're going to need to match up to the P71 driveshaft.Otherwise you're poking in the dark.
I use a ball joint press for servicing u-joints or if you have a huge heavy duty vise and the appropriate sized sockets to press and receive.You can also rent a ball joint press from a parts store.There are u-joint specific presses also that work really well but are expensive.Watch out for the hacks on youtube.
Edited by MurkyMerc (02/23/21 06:23 PM)
#4098782 - 02/23/21 11:54 PM
[Re: 66lincoln]
Loc: Napa, CA
I chased a driveline vibration in my 2008 CVPI and ended up having a custom shaft built from steel. Absolutely ZERO performance difference between the two (other than getting rid of the vibration). Its a useless swap in my opinion.
2008 P71 SAP
#4098888 - 02/24/21 02:53 PM
[Re: MurkyMerc]
Loc: Arizona
Okay, I was hoping the u-joint was more standard; as in, only one size was used.
I'll just spring for a good u-joint puller and bearing cup installer and a set of pliers for the u-joint snap rings and take a measurement with my digital calipers.
I was hoping to not have to take the shaft off the car just to measure the joint at the yoke and then put it all back together again to keep driving the car then to later take it all off again to do the swap.
I was given the '03 P71 shaft from a friend who parted out another car, so it did not cost me anything. So I'm hoping the u-joint sizing matches up with the '04 civilian. I haven't seen any '04 P71s in the salvage yards for a long time.
Edited by 66lincoln (02/24/21 02:55 PM)
2004 MGM LS (M75), 2008 CVPI (P71), 1966 Lincoln Continental convertible
#4098892 - 02/24/21 03:19 PM
[Re: 66lincoln]
Unfortunately there are about four different sizes of U-joints that were used...and the aluminum is different than the steel. You'll most likely need a hybrid U-joint (has two different sizes on it). But you should measure the existing U-joints to ensure you buy the proper one.
David Hensley Member of Northwest Panthers Car Club
2008 P71, Norsea Blue SAP -Jmod -Message Center cluster retrofit -All interior lighting converted to blue -Towncar Signature L seats, power passenger, heated front and rear -Long overhead console swap -09+ window/lock switch swap -Self installed Compustar remote start/security -Full dynamat install -Full interior swap from tan to charcoal -Trailer hitch/light controller/AirLift assist bags -Headlight relay mod
#4099008 - 02/25/21 10:19 AM
[Re: Davidzq]
Loc: Arizona
Thanks all. I just learned about the hybrid u-joint last night; found a YouTube vid where someone listed the exact part number NAPA SKF-UJ448 hybrid u-joint for this exact swap.
I found NAPA's site last night to be more helpful specifying aluminum vs steel and both sizes.
Just to make sure, I'll take a caliper measurement of the bearing caps.
