The gas tube will work for later model Panthers, but since your car has the DPFE sensor separate, I think you'd be best off modifying your existing tube.
2007 Grand Marquis LS: 5.4 swap, 9.9:1 compression ratio, Comp XE268s, NPI pistons, PI heads ported by me, Accufab upper plenum, 75mm DBW throttle body, Factory PI intake with Chinese spacers, CVPI dual exhaust, CVPI torque converter, CVPI air-box and zip tube, J-Mod, 3.55 gears, FMS Trac-Loc differential
17" Dorman CVPI steelies, BFG Comp T/A 255/45 R17s
