#4107150 - 05/01/21 07:24 PM 08- vs. 09+ aluminum driveshaft
tc092 Offline
Loc: NY
car-part.com is showing different interchanges between 08&down aluminum driveshafts vs 09&up. Is there actually any difference or does car-part just have the interchange wrong? Thanks in advance!
For reference:
#4107202 - 05/02/21 12:11 PM Re: 08- vs. 09+ aluminum driveshaft [Re: tc092]
Davidzq Offline
Fitment is exactly the same.
U-joint size may have changed.
Though the best option would be the MMX driveshaft from 99-01.
David Hensley
Member of Northwest Panthers Car Club
2008 P71, Norsea Blue SAP
-Message Center cluster retrofit
-Towncar Signature L heated power seats
-Long overhead console
-Compustar remote start/security
#4107224 - 05/02/21 02:08 PM Re: 08- vs. 09+ aluminum driveshaft [Re: tc092]
Did civilian cars still have the longer drive shaft? (wasn't much difference in length) and the cop cars had the shorter shaft with what was it, a slightly longer tailshaft housing?
#4107332 - 05/03/21 01:51 PM Re: 08- vs. 09+ aluminum driveshaft [Re: tc092]
Dmblanch Offline
Loc: Utah
I believe that the aluminum driveshaft fitted to P71's and Town Cars after 09 is a different length than the steel shaft in the non-p71's of the same age and they are not directly swappable. I think the transmission length was different, necessitating a different length shaft even though the WB may have remained the same.
Somebody who knows more than I will chime in shortly, I'm sure.
Edited by Dmblanch (05/03/21 01:53 PM)
1) 2002 White P71 - UT Training vehicle w/bad paint, 89K miles, sold.
2) 2003 B&W P71 - UT Patrol car w/bad paint, 74K miles, sold.
3) 2005 White P71 - immaculate WA Fire Chief vehicle, 54K miles, bought w/siren & lights intact, sold.
4) 2011 Black P7B - CA Sheriff vehicle, 79K miles, rented as a movie prop, sold.
5) 2008 White P71 - Idaho sheriff vehicle, 95k miles, outfitted as movie prop rental.
6) 2005 White P71 - UT University police, 74k miles, sold.
7) 2004 Silver P71 - UT Fire Dept., 104K miles, sold.
8) 2004 Toreador Red LX Sport - Want ad find, 111K.
9) 2010 White P7B SAP - UT Police, 106K, sold.
10) 2010 White P7B SAP - UT Police, 104K, sister to #9, sold.
#4107340 - 05/03/21 02:41 PM Re: 08- vs. 09+ aluminum driveshaft [Re: tc092]
tc092 Offline
Loc: NY
The aluminum driveshaft is shorter by about 3/4" and the trans tailshaft housing was longer than on civ models with steel driveshafts.
http://www.pontiacperformance.net/TechArticles/CV_Driveshaft_Swap.html
#4107486 - 05/04/21 12:53 PM Re: 08- vs. 09+ aluminum driveshaft [Re: tc092]
Davidzq Offline
P71s and Towncars had long tail transmissions.
Civilian Vic and MGM had short tail transmissions, as did Mustangs and F150s.
P71s had a shorter aluminum driveshaft to compensate for this longer transmission.
Towncars have a 3" longer wheelbase, so use an even longer steel driveshaft.
So, to use a long tranny, you must use an aluminum driveshaft.
To use a short tranny, you either use the steel driveshaft, or an aluminum driveshaft plus a spacer.
David Hensley
7 registered (DOUROS81, DudeAbides, a_d_a_m, Bellwestern80, 2 invisible), 70 Guests and 244 Spiders online.
CrystalPistol 210
JeffBoudah 62
a_d_a_m 57
