#4124694 - 10/17/21 02:17 AM Press Brake pedal ABS Light off - drive Light on
CrownVicGER Offline
Loc: Germany
Hallo,
I have a Problem with my ABS System. When I drive, the ABS Controllight is on. When I press the brakepadel the ABS light switch off. When I make a heavy brake, the ABS is working.
Anybody knows the Problem and can help me ?
I have to say its a Ford F100 with a complete Crown Vic Swap. I have also the ABS System in the car but not the normal steering wheel with the function of the
tempomat.
Thank you very much from Germany
#4124710 - 10/17/21 08:21 AM Re: Press Brakepadel ABS Light off - drive Light on [Re: CrownVicGER]
CrownVicGER Offline
Loc: Germany
Also we try to connect a diagnostic tool for the ABS Modul but there is no connection possible. We try another ABS Modul, same problem with the ABS control light and also no connection possible frown
#4124834 - 10/18/21 01:14 PM Re: Press Brakepadel ABS Light off - drive Light on [Re: CrownVicGER]
ericp Offline
Loc: pa, usa
Possible tone-ring/sensor bad. (?) My logic is system self checks OK intil it "see's " a bad pulse. On other cars I jacked a wheel and hard spun a tire to check for volts generated to feed computer.
#4125794 - 10/26/21 01:06 AM Re: Press Brake pedal ABS Light off - drive Light on [Re: CrownVicGER]
D-Fenz Offline
Loc: Free America (WV)
Originally Posted By CrownVicGER
Hallo,
tempomat.
I would love to do like a 67 F100 Swap, nice.
From my experience, the light usually means 1 of 3 things.
Low fluid, which could be actual low fluid or a problem with the master cylinder.
Bad ABS controller, but with yours, if the light goes out, I don't think that is the case.
Bad or dirty or malfunctioning wheel speed sensor(s).
Also check out the fuses but sounds like that is not the case.
Post up some pics sometime, you'll have to upload them to like imgur and then share the links.
2011 Black CVPI-Charlie Murphy II, 125K miles, Gray Interior, Fog Lights, 35% Tint All Around, Working Shotgun Release, 3.27 RAR, 2017 Mustang Wheels.
2005 CVPI-Rick James-SOLD
2000 Exploder-Charlie Murphy I-SOLD
1998 CVPI-Snow Beast-SOLD
1991 CVLX-Beast-SOLD
1987 Tempo-The Red Demon-RIP
Beef Supreme Tech News
Please put your year/make/model/mileage in your signature, it helps everyone answer your questions.
0 registered (), 51 Guests and 92 Spiders online.
bluejay_32 119
SocalSam 87
Moby_Vic 48
Davidzq 47
DudeAbides 44
Old_Guy_Stu 43
Armada Master 42
