#4128784 - 11/26/21 12:32 PM Car Stalling when Shifting into Reverse
Parkourpotato Offline
Loc: Oklahoma City
Hello all, I have a 2000 CVPI with 120K miles. It drives perfectly fine besides two things.
Whenever I turn it on in the morning, or after it has sat for about half an hour after parking it, it will stall if I shift into reverse too soon. I have to wait about 5-10 seconds or give it a little gas to increase RPMs. It hasn't outright refused to drive in reverse, just takes a few tries sometimes to back out of a space. Could be related to airflow?
The other issue, is that whenever I give it gas and it downshifts/gets to higher RPMs, whenever I let off the gas or slow down it holds the gear and won't upshift sometimes. (Holds 2nd gear at 4-5 RPM for example when it should shift into 3rd) The fluid looks perfect, so I'm thinking it's related to a solenoid(s) maybe?
The car sat in a garage for 2 years undriven before I got it. I haven't had any other issues, it drives like a champ.
#4128790 - 11/26/21 01:40 PM Re: Car Stalling when Shifting into Reverse [Re: Parkourpotato]
Check the IAC (Idle Air Control) valve.
#4128792 - 11/26/21 01:47 PM Re: Car Stalling when Shifting into Reverse [Re: Parkourpotato]
Tenevic_P71 Offline
Loc: US
This is a computer controlled engine. Hook up a scan tool to check for pending codes. Check fuel trims, MAF, o2 readings.
2006 P71 119k miles, 3.55 traclock
#4132906 - 01/14/22 11:11 AM Re: Car Stalling when Shifting into Reverse [Re: Parkourpotato]
Loc: Oklahoma City
I'm just updating this post to say it was the O2 sensors. Replacing them fixed it entirely.
