#4129370 - 12/03/21 05:31 PM 18x11 wide rims fit on the back of an aero
hkerekes Offline
Loc: NC
Has frame clearance and fits under the fender.
Yes my garage is a mess, i havent been home to organize it.
Edited by hkerekes (12/03/21 05:31 PM)
#4129396 - 12/03/21 08:13 PM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
dixiebandit69 Offline
5.4 Club
Loc: Texas
Yeah, but will the TIRES fit? What size were you thinking of running?
2007 Grand Marquis LS: 5.4 swap, 9.9:1 compression ratio, Comp XE268s, NPI pistons, PI heads ported by me, Accufab upper plenum, 75mm DBW throttle body, Factory PI intake with Chinese spacers, CVPI dual exhaust, CVPI torque converter, CVPI air-box and zip tube, J-Mod, 3.55 gears, FMS Trac-Loc differential
17" Dorman CVPI steelies, BFG Comp T/A 255/45 R17s
#4129406 - 12/04/21 08:31 AM Re: 18x11 wide rims fit on the back of an aero [Re: dixiebandit69]
hkerekes Offline
Loc: NC
295/40/18
They stretch on the rim a little so they fit just fine. I may have to cut the fender a little bit and add some flares due to the desired ride height, but getting the rims to fit was the first step.
The fronts are not going to be so easy. I may end up having to custom order rims at $575 each. I believe i need a -20 to -30 offset to clear the frame/swaybar. I really really hope i can avoid that considering i should have 4 rims.
#4129414 - 12/04/21 09:41 AM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
Check clearance with one side of the suspension jacked up. Looks like it might could rub with some body roll.
1988 CVLX Formal Roof (Love Boat) POTM July 2019, Aug 2020, & Oct 2021, 58K
This, of course, was merely the semi-delirious notion of a fever-patient, but I remember that it struck me at the time as being eminently practical and feasible.
#4129466 - 12/04/21 08:20 PM Re: 18x11 wide rims fit on the back of an aero [Re: Old_Guy_Stu]
hkerekes Offline
Loc: NC
Im taking a sawzall to the fenders. I already know its going to need it since we already [censored] up a front tire. I may get some cheap fender flares, or just leave it. Having a car you really dont care what it looks like is awesome.
#4129476 - 12/05/21 05:59 AM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
I was thinking more of the rear wheelhouse, on the inner side. I guess you can wait and see where the tire hits and clearance it with a sledge.
#4129562 - 12/05/21 11:18 PM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
hkerekes Offline
Loc: NC
It looked to have plenty of clearance there but if not i can make some. Worse case i have to do a ghetto tub job, but it wont be a problem since looks are irrelevant.
#4129600 - 12/06/21 11:04 AM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
18x11 with what backspacing?
#4129614 - 12/06/21 01:52 PM Re: 18x11 wide rims fit on the back of an aero [Re: GM_Guy]
hkerekes Offline
Loc: NC
18x11 +8 offset
no spacer at all.
#4129714 - 12/07/21 06:52 PM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
BlackNFast Offline
Loc: Hills and Hollers of Tennessee...
I run 295/40/r18 nitto on 18/9.5 rims with 2 inch spacer.
Rubs pretty bad on bumps,haven’t rolled the fenders yet because I haven’t trusted anyone to do so,but soon hopefully. Around 7.125 on backspacing I believe.
Edited by BlackNFast (12/07/21 06:55 PM)
98 Marquis ultimate edition - Forged 4.6 2v w/Vortech v2 @ 14 pounds Max boost. T56 swapping next few months.
458 Rwhp and 441 FPT
Currently own:
1979 f250 Camper Special w/460 4 Barrel stock
2003 Silverado 2500hd w/ 6.0 LQ4 stock
#4129724 - 12/07/21 08:59 PM Re: 18x11 wide rims fit on the back of an aero [Re: BlackNFast]
hkerekes Offline
Loc: NC
We almost ruined a 285/35/18 tire due to rubbing on the front fender. The good old sawzall is going to remedy that problem.
The 18x11 does fit upfront but i didnt get to check the clearance at full lock. With a 15mm spacer and 8 offset rim it clears the upper balljoint and my wilwoods.
#4129754 - 12/08/21 07:37 AM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
BlackNFast Offline
What are u doing with the car,looks like fun project to me.
Currently own:
#4129794 - 12/08/21 04:18 PM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
hkerekes Offline
Loc: NC
Endurance road racing. We run with Luckydog, Lemons, and will eventually end up running a Champcar or AER race but it will be less competitive there.
Its fairly fast now, have two second place and one third place trophy in Luckydog last year. We have the ability to win the Lemons Road Atlanta race this weekend. Whether we will or not is another story.
Moderator:  RF_Overlord
0 registered (), 35 Guests and 89 Spiders online.
SocalSam 63
RF_Overlord 41
Dmblanch 38
