#4132598 - 01/11/22 05:16 AM HVAC Air Flow Issue
White Falcon LS Offline
Loc: SoCal
If I turn on the HVAC to any position where it's suppose to vent from the dashboard towards the cabin (VENT, NORM A/C or MAX A/C - manual controls), it vents in defrost mode to the windshield instead. After some time goes by, and the engine is at idle with high vacuum (e.g. at a stop sign), it'll switch to the dashboard air vents on its own.
If this was a constant vacuum leak, I reckon it would continually be stuck in defrost mode, but this one has me scratching my head. Pretty sure it's a vacuum issue, considering my auto parking brake release also stopped working. Thanks!
Lucifer: '01 Grand Marquis GS Convenience
Tuned By Marty @ Mo's Speed Shop
In Memory of Ned Nuss, Rick Richardson and Matt (2vmodular)
#4132616 - 01/11/22 09:59 AM Re: HVAC Air Flow Issue [Re: White Falcon LS]
Definitely a vacuum issue. Maybe the vacuum accumulator or the line going to it? There's only 2 miles of vacuum lines in these cars, so have at it!
1988 CVLX Formal Roof (Love Boat) POTM July '19, Aug '20, Oct '21, Feb '23, 64K
This, of course, was merely the semi-delirious notion of a fever-patient, but I remember that it struck me at the time as being eminently practical and feasible.
#4132666 - 01/11/22 03:52 PM Re: HVAC Air Flow Issue [Re: White Falcon LS]
Davidzq Offline
Do you have manual or electronic controls?
The EATC unit uses o-rings which eventually crack and leak. I would suspect the one for the panel door has cracked. #007 is the size of the o-rings.
It's also possible the panel door hinge has broken, leaving the door stuck.
David Hensley
Member of Northwest Panthers Car Club
2008 P71, Norsea Blue SAP
-Message Center cluster retrofit
-Towncar Signature L heated power seats
-Long overhead console
-Compustar remote start/security
#4132790 - 01/12/22 08:49 PM Re: HVAC Air Flow Issue [Re: White Falcon LS]
Dmblanch Offline
Loc: Utah
Given the frequency of o-ring failure, that'd be my first bet, fortunately its cheap and easy to replace them all. Everybody who buys them has extras left over.
1) 2002 White P71 - 89K miles. 2) 2003 B&W P71 - 74K. 3) & 6) & 11) 2005 White P71 - 54K, 74k, 115K. 4) 2011 Black P7B - 79K. 5) 2008 White P71 - 95k. 7) 2004 Silver P71 - 104K. 8) 2004 DT Red LX Sport - 111K. 9) & 10) 2010 White P7B SAP - 104K & 106K. 12) 2006 White P71 - scrapped. 13) 2007 Gray LX Sport - 125k. 14) 2006 White MGM LS Premium - 93k. 15) & 16) 2009 White P71 SAPs - 109k & 94k, 17) 2011 White P7B SAP - 67k, 18) 1994 Blue LX Aero - scrapped, 19) 2007 Oreo P71 - 100k, 20) 2007 White LTC Signature -98k, 21) 2004 Silver Marauder - 142k.
#4133368 - 01/19/22 08:33 PM Re: HVAC Air Flow Issue [Re: White Falcon LS]
1990LTD Offline
Loc: Nova Scotia
Definitely O rings.
What's the likely issue if the airflow is always at least slightly coming from the vents? It'll still switch between the other modes but it's always blowing a bit from the vents, it's easy enough to close them but I'm losing plenty of airflow and heat that way.
2007 Ford Escape - 3.0 Duratec / CD4E / 2WD - Rear converter delete, dual exhaust.
2008 Mercury Grand Marquis Ultimate Edition - 4.6 / 4R75E / 2.73 - rear coil conversion - DD
0 registered (), 78 Guests and 8 Spiders online.
RF_Overlord 32
speedfreak 28
Bellwestern80 27
LordAeneas 24
PrincePolaris 21
Traffic22 16
