#4132706 - 01/11/22 10:06 PM Burning Smell On Cold Start Only
46Mod99 Offline
Loc: Hudson, New Hampshire
I recently (last summer) had my 99 LTC get engine work at a shop, to replace head gaskets (and plane heads), oil pan and gasket, rear main seal, timing chain and tensioners, and valve cover gaskets. Rationale being stop oil leakage primarily from the head gaskets leaking onto the exhaust, which I'd smell on vent coming to stops. The shop wound up replacing an exhaust manifold as well, I suppose the original broke in removing the engine.
Since the repair, if there's any oil leakage remaining it's minimal enough I don't breathe in oil at red lights anymore.
But the car now has a new behavior. On cold starts only, such as the first start of the day or after sitting for a few hours, a few seconds after startup there's a strong crisp burning smell through the vents that lasts for about fifteen seconds, it's almost like gasoline, nothing like antifreeze or oil. It doesn't reoccur on restarts. It didn't do this before the repair.
If it's burn-in smell from the new manifold it hasn't diminished at all despite it being several months since the repair.
The car still has the original plastic intake manifold. I don't see any obvious or significant antifreeze leakage, although the smell is nothing like antifreeze.
I'm under shop warranty and I do intend to take it back soon for their opinion / ideas and check if any oil leakage is reoccurring where repairs had been done. I'm wondering if anyone has any similar experience with this issue to know what's likely the cause of the burning smell.... thanks.
Edited by 46Mod99 (01/11/22 10:14 PM)
1999 Lincoln Town Car Cartier 112k and counting :: Quad LED Projectors :: Fog Lights :: Heavy Duty Shocks :: 03+ Headrests
2003 Mercury Grand Marquis GS 161k and counting :: LED Projectors :: Driving Lights :: Rear Reflector Illumination
1988 Lincoln Town Car Base 87k and counting :: LED Integral Beam :: Fog Lights :: Cartier Seats
#4132796 - 01/12/22 09:46 PM Re: Burning Smell On Cold Start Only [Re: 46Mod99]
46Mod99 Offline
Did a little sniffing around today, smell is only detectable on the passenger side of the engine and it is strongest five to fifteen seconds after a cold start. However my passengers tell me they smell it entering the vehicle.
I'm suspecting it's an exhaust manifold or gasket leak from the new manifold or gasket, which my shop receipt suggests are from Dorman. It's a foreign smell to me because I'm not used to smelling exhaust other than after passing through the cats. This also explains why I get drowsy fast on long drives.... it's going back to the shop LOL.
#4132914 - 01/14/22 12:08 PM Re: Burning Smell On Cold Start Only [Re: 46Mod99]
metalpanther Offline
Loc: USA
Does sound like an exhaust leak.
If I'm not mistaken, modern cars tend to run rich on gas before the car has warmed up. That may be why its so noticeable on cold start
2005 P71
