Page 53 of 53 < 1 2 51 52 53
#4061754 - 05/04/20 04:10 PM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: dRock96Marquis]
MercMike2iv Offline
Loc: CA
I have a 2003 Mercury Grand Marquis. I like the look of the stock aluminum wheels but wanted to get a more aggressive look. Thiught about aftermarket then through the help of the info off this forum I found a set of 2017 Mustang Gt 18" wheels local for 200$ with tires.
Installed and they fit perfectly. Slightly lower offset so the wheel sits more flush with the body line and gives it a good aggressive stance without needed a real low profile tire and taking away the natural look the Mercury already has.
#4062574 - 05/10/20 09:04 PM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: dRock96Marquis]
HavocMan Offline
Loc: NJ
Does anyone know if Mach 1 wheels from the 2003 and 2004 SN95 Mach 1 Mustang will fit 2003+ Crown Vics?
2011 CVLX
#4062780 - 05/12/20 10:52 AM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: dRock96Marquis]
Yes, they are lower offset and the edge will sit just outside the fender up front and fit the rear perfect.
#4062784 - 05/12/20 11:07 AM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: BlackVic_P71]
HavocMan Offline
Loc: NJ
WOW - the rear really looks great!! What size are those wheels? Front & rear all the same size? What size tires? All the same, front & rear?
I wonder if the back of the mounting flange could be machined down a bit to move the front wheels into the fenders a little??? hhmmmmmmmm............
...and THANKS for the reply!
2011 CVLX
#4062842 - 05/12/20 05:21 PM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: HavocMan]
17x8 wheels, +30 offset and 255/50-17 tires all around
I don't believe the mounting flange is thick enough to machine down and still have a mounting flange to use
#4062856 - 05/12/20 06:20 PM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: BlackVic_P71]
HavocMan Offline
Loc: NJ
OK, cool!
...awww dangit
I was hoping for a cheaper alternative to the Forgeline FL500 LOL
2011 CVLX
#4062894 - 05/12/20 09:25 PM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: HavocMan]
85GT Offline
Loc: NYC
OK, cool!
Suggest you look to 18" wheels, 255/45 18. The 255/50-17 i have on my caprices. They are practically extinct. Two nitto's, a riken and a hankook is all that's left. Maybe some oddball brands.
08 CVPI
85 Mustang GT w/4R70W
91 Caprice
95 Caprice
#4062908 - 05/12/20 10:01 PM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: 85GT]
HavocMan Offline
Loc: NJ
Yeah, I was leaning towards 18's anyhow (18x8 or 9 F, 18x10 R. So it's looking like I might have to bite the bullet and go for the Forgelines.
2011 CVLX
#4102230 - 03/19/21 07:49 PM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: dRock96Marquis]
MercMike2iv Offline
Loc: CA
2018 Mustang GT two tone 18" wheel +30 offset
245/50R18 tires
#4103506 - 03/31/21 01:54 PM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: MercMike2iv]
Darkant Offline
Loc: NJ
Looks Great!
2001 Grand Marquis Limited
2001 Crown Victoria Police Interceptor spac
2009 Crown Victoria Police Interceptor
#4106392 - 04/26/21 05:26 AM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: dRock96Marquis]
Rabies Offline
Loc: Eastern Iowa
I still have yet to see any box cars with mustang wheels. Only steel wheels or gangster wheels. Hub size or bs issue?
#4106394 - 04/26/21 06:21 AM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: dRock96Marquis]
Backspacing issue. You'll need about a 2" spacer to get late-model Mustang wheels to fit anything earlier than '03.
1988 CVLX Formal Roof (Love Boat) POTM July 2019 & Aug 2020, 56K
#4106580 - 04/27/21 06:41 PM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: dRock96Marquis]
Rabies Offline
Loc: Eastern Iowa
i see. would it still be an issue if i converted to 98-02 spindles/hubs/brakes?
i do know the older cars had such a rediculously long hub.
i was just told to get those spindles for front brakes. getting them this weekend from yard. not sure if they will pooch the wheel out more or less either. google has nothing for the swap
Edited by Rabies (04/27/21 06:57 PM)
#4106602 - 04/27/21 09:30 PM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: dRock96Marquis]
98-02 track width is the same as your box up front, but the rear axle is a little wider. Maybe 1/2 inch? Won't help with the backspacing issue. You'll still need spacers even with the big brakes.
#4112100 - 06/10/21 05:00 AM Re: Panther Platform Wheel & Tire Swaps - FAQ [Re: dRock96Marquis]
03MM Offline
Loc: Pennsylvania (PA)
So I just recenly bought a 2000 CV lx and would like to upgrade the wheels that came with it. I'm a huge fan of how the FR500 wheels (with spacer) look on the the 98-02 CV, but I am trying to avoid using spacers.
My other options for wheels would be the Charger/Challanger wheels. (Scat Pack/hellcat specifically) After doing some reaseach though and fiding out the offset to the non widebody is an the 20-22ish mm area I realized I would again have to run spacers. After looking a little more and into coming across the widebody wheels I notice that their offset seem to be closer to what the 98-02 came with stock, 98-02 (-6mm) and WB Charger (-2.5mm). So now this has me thinking, the specific wheels I am looking at are 20x11 with an offset of -2.5mm.
So going off of the information I've read on here I "should" be able to put these wheels on (in the rear at least) and still have them be tucked into the wheel well correct?
Moderator:  RF_Overlord
2 registered (Davidzq, 1 invisible), 44 Guests and 306 Spiders online.
JeffBoudah 36
Davidzq 33
