I got the starter cable harness out
That was another pain
I had to take out the ac box to do it I just could not see where the bolt was and also there is no room to turn a wrench in there
Looks like I can remove the bracket from the wires so I could just buy the cables separately and reassemble them with the bracket
The other that wire goes to the solenoid comes from somewhere else so I probably won't change the whole thing I am thinking maybe just cut it back to a convenient spot and splice on a new wire the only thing I am debating is what terminal should I use
I saw some starters that come with a small pigtail of wire and some sort of one pin connector so I would need to find a plug that would fit that or I could get the starter with a screw terminal and just use a ring lug on it
