inner fender cut out exactly as the other side and the lower front sat in my acid bath
That will be in there for a day or two so its onto the front door. Onto my worktop it goes and the base stripped of paint just in case there is any rust underneath
Which is a good job because if you look closely in the next picture you will just be able to see some rust marks that would have bubbled the new paint up.
I knew of the underside rust but hadn't seen it for a bit, so door turned round and here is my next job!
Should be simple enough to sort out....lip bent back, rust cut out, a spell immersed in acid and weld in new steel.
Andy.
www.lowcamaro.com
