Corner/Marker Lights
1992-1997 Crown Victoria share corner lights. There are two different styles available depending on the model.
Fleet and base model.
LX model with built in corner lamp.
1998-2011 Crown Victoria share corner lights.
1992-1997 Grand Marquis share corner lights. 1992-1994 are textured, 1995-1997 are clear. There are two different styles available depending on the model.
1992-1994 LS corner lamp
1992-1994 GS corner lamp
1995-1997 GS corner lamp
1995-1997 LS corner lamp
1998-2002 Grand Marquis share corner lights.
2003-2005 Grand Marquis and Marauder share corner lights. Grand Marquis are chrome, Marauder has black inserts.
2006-2011 Grand Marquis share corner lights.
You can swap corner lights among 98+' Panthers (excluding 98'-02' Grand Marquis) with minor modifications to mounting locations and wiring. Marauder corner lamp swap onto a Crown Vic is a very popular appearance modification.
You can not swap 98'-02' GMQ corners on a 92'-97' model due to size difference. Even though they look identical, they are not.
Header Panels
1992 Crown Victorias have unique header panels.
1993-1997 Crown Victorias share header panels.
1998-2011 Crown Victorias share header panels.
1992-1994 Grand Marquis share header panels.
1995-1997 Grand Marquis share header panels.
1998-2002 Grand Marquis share header panels.
2003-2005 Grand Marquis and Marauder share header panels.
2006-2011 Grand Marquis share header panels.
Rear Body Parts
Crown Victoria
1992
1993-1994
1995-1997
1998-2011
Grand Marquis
1992-1994
1995-1997
1998-2002
2003-2005
2006-2011
Marauder
Rear Doors
1992-1997 Crown Victorias have unique rear doors which will not fit any newer models but they can be interchanged between the years. 1992-1997 Grand Marquis has different rear doors so you can not put a CV door on GMQ.
1998-2011 Crown Victoria, 1992-2011 Grand Marquis and Marauder doors are the same. The mounts may be different as well as any hardware inside the door such as door locks, window regulators and any wiring. Exterior trim may also be different. The only exception is the extended version of Crown Vic which has longer doors which will not fit any other models.
Rear Bumper Covers
1992-1994 Crown Victorias share rear bumper covers.
1995-1997 Crown Victorias share rear bumper covers.
1998-2011 Crown Victorias share rear bumper covers.
1992-1994 Grand Marquis share rear bumper covers.
1995-1997 Grand Marquis share rear bumper covers.
1998-2011 Grand Marquis share rear bumper covers.
Marauders have unique bumper covers.
The interchange between years and models varies. It depends if you are willing to swap other parts to make the bumper covers work.
People often want to install Marauder bumper cover on a 98'+ Crown Vic or Grand Marquis. It is a direct bolt on for both cars. On a Grand Marquis however, you will also need to swap your reverse lights panel or your trunk lid won't close properly.
Trunk Lids
1992-1993 Crown Victorias share trunk lids but have different trim. 93'-94' has a reflector, 92' doesn't.
1995-1997 Crown Victoria share trunk lids which are also made from aluminum.
1998-2011 Crown Victoria, Grand Marquis and Marauder share trunk lids but have different reverse lights panel and trim on the outside depending on the year and model of the car (police, civilian, etc.)
1992-1994 Grand Marquis share trunk lids.
1995-1997 Grand Marquis share trunk lids which are also made from aluminum.
You can not put a 1992-1997 Crown Victoria trunk lid on a 1992-1997 Grand Marquis because the shape of rear windows is different which makes the trunk lids curve differently as well.
Often people want to put a Crown Victoria reverse light panel on a Grand Marquis and vice versa. To swap a Crown Vic panel on GMQ, it's a simple bolt on. Remove your old panel and install a new one. However, you will have a gap between a trunk lid and a new panel because Grand Marquis has a license plate cut-out in the bumper cover. To do a clean install, you will also want to swap a bumper cover.
Now, to swap a Grand Marquis panel on a Crown Vic, you would have to swap a bumper cover as well as the panel. You can not make it work without installing a Grand Marquis bumper cover.
Taillights
1992-1993 Crown Victorias share taillights.
1995-1997 Crown Victorias share taillights.
1998-2011 Crown Victorias and Marauder share taillights but have different trim and bulb variations between the years.
1992-1994 Grand Marquis share taillights.
1995-1997 Grand Marquis share taillights.
1998-2002 Grand Marquis share taillights.
2003-2011 Grand Marquis share taillights.
Often people want to swap 98'+ Crown Victoria taillights on a 98'+ Grand Marquis and vice versa. They are a direct bolt on. However, the bulb locations may be different. Also, the exterior trim may not match.
1995-1997 Crown Victoria taillights will not fit a 1995-1997 Grand Marquis due to obvious size differences.
Quarter Panels
1992-1994 Crown Victorias share quarter panels.
1995-1997 Crown Victorias share quarter panels.
1998-2011 Crown Victorias, Grand Marquis and Marauder share quarter panels. 2005 model year had a quarter panel mounted radio antenna.
1992-1997 Grand Marquis share quarter panels.
